Oops, my obsession with computers from my childhood strikes again!
Well, I did this to see what the result was:
Basically a 12v fan blowing straight onto the MMU. And it sort of helped, it took at least 45 minutes for the failure to occur, about 3 times longer than before. Recovery was a lot faster too
I think this really cements the fact that the MMU is bad, which is a real shame.
I have some dead video cards that have some very neat little heatsinks with integrated fans, so I'll see If I can extend the time further.
Fit a PC water cooling block on it and have the only water cooled Apple II on the planet. ;-)
Tomswork
Post by Tomswork »
@rubber_jonnie
I have found spare parts board will update you later with a picture of the mmu ic my friend says its the iou ic thats different let's hope I know the board layout is different.do you have the enhanced setup ?
Tom
stephen_usher wrote: Tue Apr 18, 2023 4:04 pm Fit a PC water cooling block on it and have the only water cooled Apple II on the planet. ;-)
Don't tempt me...
Other things under consideration:
  1. A peltier cooling block
  2. An M.2 cooling block with additional cooling fans, or water cooling
  3. baking the MMU (See Adrians Digital Basement)
I'm not done yet!!
Tomswork wrote: Tue Apr 18, 2023 8:23 pm @rubber_jonnie
Tom
Wow that's amazing!!
Mine is not an enhanced IIe, just the standard one.
Thank you sir.
Tomswork
Post by Tomswork »
@rubber_jonnie
Mmu and my spare board
Tom
@Tomswork thanks, I am in the office today so will look properly when I get home.
You're a star.
Tomswork wrote: Wed Apr 19, 2023 5:19 am @rubber_jonnie
Tom
Hey Tom, my MMU part number matches yours, however my IOU is different, as your friend suggested, with a part number of 344-0022 instead of the 344-0020 of yours.
Thanks
Tomswork
Post by Tomswork »
@rubber_jonnie
Let me know i can put the mmu in a picture mailer
Tom
Tomswork wrote: Thu Apr 20, 2023 8:16 pm @rubber_jonnie
Tom
That would be a lifesaver Tom, I'll PM you.
