Darklord wrote: 20 Apr 2023 16:37
No matter how fast that person runs, IF the treadmill/conveyor belt
keeps up with them, they are *not* going to move forward.
Because that is a " direct drive of the wheels" like a car. So a person on a treadmill would be correct as you describe.
However this is not the same for a plane....
Now strap wings on to that running person. They still won't fly,
no matter how fast they run, because they are not moving forward
and thus no movement = no lift = no flight.
There is a physical disconnect between the plane and the runway via the wheel bearings. Simply adding wings will not work because you have omitted the jet engine part of the equation.
The jet engines push against the wings of the plane, a person running on a treadmill pushes against the ground/treadmill.
If you wanted a treadmill analogy, then imagine the person running on the treadmill which is covered in oil. Regardless of how fast the person runs, or how fast the treadmill goes. There is no direct connection exactly between the two because of the oil is separating the two forces.
If you forget the actual friction side of it all, the oil is separating the treadmill from the persons feet. Neither one can affect the other. So now if you strap a jet engine onto the back of the person he will just inherently be pushed forward. It is exactly the same with the plane.
The car analogy is different because if the car was going 100mph forward, and the conveyor belt was travelling 100mph backwards. Then the car would be perfectly stationary and would not move.
However, if you put the car in neutral, it is irrelevant how hard you step on the gas, it does not contribute to any motion. The conveyor belts speed would be irrelevant because the car is in neutral and does not affect anything other than the wheel speed. So then again if you strap a jet engine on the back of the car it would just inherently move forwards.
The bottom line of all this is, If the plane is travelling 100mph forwards on the runway, the wheels are turning at 100mph. Now if the runway/conveyor belt now goes 100mph backwards, the wheels are now turning at 200mph. The plane is pushed forward by the engines and would still be going at 100mph, and would still take off as it would ordinarily do in any other regular takeoff.
