Let's build a CTPCI!
Rustynutt
Re: Let's build a CTPCI!
Post by Rustynutt »
foft wrote: 21 Mar 2023 19:50 Just to add a couple of final pics.
Here it is, now I need to squeeze it back into the Space Case:
Now I need to find some software other than gembench to run :lol:
How is the CT63 buffering working in lieu of a "clock patch" with SCSI and Floppy DMA? I've ran the CT60e up to 46MHz max, but no luck stabilizing SCSI/Floppy at 23MHz bus.
Kronos has a few comparative benchmarks included with the archive.
Of interest with your setup, one a CT60 around 100MHz with SuperVidel, and a Vampire bench included.
foft
Post by foft »
The Atari ‘green bar’ dma test passes. Is that accurate enough?
marss
Post by marss »
I buy one if you have one left ;)
foft
Post by foft »
So, did anyone make any 3d stuff for these?
P.S. my google fu is failing me, can someone please link me to the register specs for these Radeon cards?
mikro
Post by mikro »
When CTPCI was a thing, there wasn't any 3D printing available. ;-) And then everybody with CTPCI disappeared...
Some info abour Radeons can be found here: https://mikrosk.github.io/ct60tos/ctpci ... erview.htm
foft
Post by foft »
Ah no I meant 3D graphics, not 3D printing:)
Register level docs, I mean something like Matrox released here. I remember I had a similar doc for the Rage Pro iirc.
http://www.bitsavers.org/pdf/matrox/G40 ... un1999.PDF
I didn’t find something like the RV280
mikro
Post by mikro »
Not really. I remember Saulot has done some experiments with double buffering: https://bus-error.nokturnal.pl/article1 ... with-XBIOS
foft
Post by foft »
foft wrote: 21 Mar 2023 16:37 There is also a 2nd problem, I get a parity error depending on how I position the card, so perhaps there is a bad connection somewhere.
I realised the likely cause of this one. I'm using 40 IDC wire cables to connect it up. I'm meant to use 80 wire cables, which basically have a ground line between each one.
foft
Post by foft »
marss wrote: 22 Mar 2023 09:01 I buy one if you have one left ;)
Well I managed to order 4 extra PCBs and 9 extra chips. I might have to put some of them together at some point...
P.S. If anyone wants to swap a completed one for a supervidel let me know.
Post by HigashiJun »
foft wrote: 22 Mar 2023 20:35
Better then to set a queue for interested folks ?
