Let's build a CTPCI!
markus0321
Re: Let's build a CTPCI!
Post by markus0321 »
Hi.
Are these attached gerber files complete or just outer layers without power and ground?
I tried to order for production and it only detects that there are 2 layers, is this correct?
Edit:
Sorry, I didn't read that you are still working on the inner layers... :roll:
But these PCBs look so nice that I was tempted to check them in JLCPCB :D
foft
Post by foft »
Ctpci has 4 layers
Ctpci slots has 2 layers
Pretty sure pcbway detects the inner layers fine
markus0321
foft wrote: 17 Mar 2023 12:22 Ctpci has 4 layers
In fact, PCBWAY detects layers correctly, but it is more than twice as expensive there as in JLCPCB.
So I can order these boards at PCBWAY for testing, or maybe you will still improve these gerber files?
foft
Post by foft »
I wasn’t going to edit them more, unless the pcb does not work. I guess its just a case of renaming the inner layers to the one jlcpcb expects.
markus0321
foft wrote: 17 Mar 2023 17:30 I wasn’t going to edit them more, unless the pcb does not work. I guess its just a case of renaming the inner layers to the one jlcpcb expects.
The file names were actually wrong. Instead of the extension g1 I changed to gl2 and g2 to gl3 and it loaded correctly.
Thank you for help.
I wonder if this will work....
:D
foft
Post by foft »
Getting there. Lots of 0603s last night, doing these by hand without paste - all the 0.1uFs and the 8.2Ks. Board now covered in flux!
Just a few more small parts to go, then onto the chips and the SMD headers. After which it'll need a good clean!
foft
Post by foft »
Time for these chaps:
My method (getting better but still a relative beginner) is:
Stick them down with tape in place:
Tack the corners with a big blob of solder!:
Put tacky flux the whole way along:
Drag solder, watching on this:
Then for bridges remove excess with some braid and if it's not too much excess another blob of flux will usually help it out some!
Here is the result, still needs a good clean but getting there:
Post by HigashiJun »
Nice progress !
Hope the final result will be good.
PLX. I used to work for them designing PCIe chips
@foft
Oh, and by the way, if you later want to sell your surplus, I'm in for one CTPCI (in kit or built).
Cheers.
