There is a pattern in the errors, it looks like either two data bits have a problem (or some address thing which leads to the same).
???? ?PPX XPPP PPPP
X=fail
P=pass
?=not in screenshot
Can yarrt write to a file to capture more info?
I can check the schematic this evening to see which traces/connections this would mean.
Or send it back and I’ll sort it out, sorry!
DFB1 Support thread
Re: DFB1 Support thread
@Fletchfoft wrote: 22 Feb 2023 07:08 There is a pattern in the errors, it looks like either two data bits have a problem (or some address thing which leads to the same).
???? ?PPX XPPP PPPP
X=fail
P=pass
?=not in screenshot
YAARRTT will dump to serial, if that helps?
Looks like a pretty consistent pattern where bits 7 and 8 of the 32 bit bus are stuck high.
I can't see anywhere where they might obviously short to the 5V rail, but they're pulled high so it's possible the solder joints to the buffer chips buffer chips at the bottom, right of the LEDs, have dried out? IC5 and IC6.
Bit 7 is on IC6, bit 8 is on IC5.
Get a magnifying glass on it?
Fletch
Maybe I ought to mail it back to you and you can look at it. I solder a bit, but the soldering on this board is certainly more precise than I am comfortable with.
Are you okay with that? I'll certainly pay you something for your trouble and for the return postage.
Let me know.
Let me know.
???? ?PPX XPPP PPPP
X=fail
P=pass
?=not in screenshot
foft
Sure of course, sent you a pm. Sorry about this!
foft
Thanks @Badwolf. I think your analysis was spot on here, the board is working now.Badwolf wrote: 22 Feb 2023 10:06 I can't see anywhere where they might obviously short to the 5V rail, but they're pulled high so it's possible the solder joints to the buffer chips buffer chips at the bottom, right of the LEDs, have dried out? IC5 and IC6.
It wasn't obviously an issue on the usb microscope, though the solder looked a bit thin on one side of these bus drivers. To be safe I re-soldered every pin on every one of the SMD chips to be sure, adding some extra solder in places. It started working after re-doing the four bus drivers, which ties in.
It's now sitting on YAART doing an extended run.
Top banana. Shame you had to ship it back, but grand it's back up and firing on all cylinders.foft wrote: 11 Mar 2023 08:27 It wasn't obviously an issue on the usb microscope, though the solder looked a bit thin on one side of these bus drivers. To be safe I re-soldered every pin on every one of the SMD chips to be sure, adding some extra solder in places. It started working after re-doing the four bus drivers, which ties in.
markus0321
I have a question only indirectly related to DFB1.
A friend sent me a faulty falcon motherboard.
To my surprise, the board came to life when I inserted one of my DFB1 cards into it. (the board itself or equipped with CT63 generates only colored stripes and patterns on the screen)
The question is what can be damaged on the falcon board, maybe someone knows right away without analyzing the diagrams what could be the reason for the damage? (I think it's CPU or Combel but maybe I'm using a mental shortcut)
DoG
markus0321 wrote: 19 Jul 2023 08:34 I have a question only indirectly related to DFB1.
The jumper between 20-22 on the expansion port is needed if there is not a card there. Could it be that simple?
Don't think it's the BG jumper as CT60 does the same. A missing BG jumper normally means white screen anyway.
Could it be the motherboard ROM? Try disabling flash on DFB1 and see if you get the same results.
markus0321
I know that the jumper must be put on when there is no card. It must be something else on the board and the diagram is not interactive, I only have scans.DoG wrote: 19 Jul 2023 09:37markus0321 wrote: 19 Jul 2023 08:34 I have a question only indirectly related to DFB1.
