Hi,
I'm modding my STe with the "1.44 FLOPPY UPGRADE PCB V7.1" and I'm a bit confused with assembly documents for every versions except v7.1.
My pcb :
So I guess there is no more SIL array to solder as I can see smd 1k arrays in the middle of the pcb ?
A : D0 for floppy drive A. The pad should stay unsoldered and a wire goes to the floppy drive but where exactly on a Sony MPF920 ?
B : D1 for floppy drive B. Without any drive, pad should be bridged.
C : MCF, this Media Change Fix pad should stay unsoldered with Dual Tos (2.06)
D : P1 wired to W301 pad 1 (right square one)
E : P2 wired to W301 pad 2 (middle round one)
Third and last question, is there any precaution to follow if this pcb is used with your "FLOPPY CABLE FLIP KIT [0208]"
Thanks in adavance !
1.44 FLOPPY PCB v7.1
Astuck
Re: 1.44 FLOPPY PCB v7.1
Correct.Astuck wrote: 10 Jan 2023 16:50 So I guess there is no more SIL array to solder as I can see smd 1k arrays in the middle of the pcb ?
5th picture down.A : D0 for floppy drive A. The pad should stay unsoldered and a wire goes to the floppy drive but where exactly on a Sony MPF920 ?
https://exxosforum.co.uk/atari/last/floppy/index.htm
Correct.B : D1 for floppy drive B. Without any drive, pad should be bridged.
Solder it.C : MCF, this Media Change Fix pad should stay unsoldered with Dual Tos (2.06)
I only kept it as "breakable" if someone had issues. But I never had any reports of issues with it enabled.
Image on the "FITTING TO STE" section.D : P1 wired to W301 pad 1 (right square one)
None that I am aware of no.Third and last question, is there any precaution to follow if this pcb is used with your "FLOPPY CABLE FLIP KIT [0208]"
Astuck
Perfect !
Many thanks for these light fast answers.
DaveC
Might be worth cutting the trace between the drive select pins on the floppy flip kit if you haven't already put it together.Astuck wrote: 10 Jan 2023 16:50 Third and last question, is there any precaution to follow if this pcb is used with your "FLOPPY CABLE FLIP KIT [0208]"
Otherwise the drive will respond to both A: and B: requests.
You can see where in this post of mine
viewtopic.php?p=59423#p59423
I think STF is fine. Only 1 drive select on the internal.DaveC wrote: 10 Jan 2023 20:31 Might be worth cutting the trace between the drive select pins on the floppy flip kit if you haven't already put it together.
Looking at the STe, looks like Atari wired both A&B to the internal connector :roll:
Astuck
@DaveC
Thanks for the tip about STe, sadly the message arrived 2 hours after the flip floppy kit was assembled :?
Just cut pin12 on the floppy drive connector and have done with it.Astuck wrote: 10 Jan 2023 22:41 @DaveC
Thanks for the tip about STe, sadly the message arrived 2 hours after unflip floppy kit was assembled :?
Astuck
@exxos
OK for pin12.
Looking for the HD selec pad inside MPF920, I've just noticed that you may have forgotten to correct D0 SEL on this one :
OK for pin12.
DaveC
It shouldn't matter if you're using the floppy flip, d0 and d1 have a trace between them on the drive connector side of the pcb as well.
zfrenchy
I am also installing your HD FLOPPY MOD 7.1
The Sony MFP920-E I ordered from Exxos Store is a bit different than the photo.
Where to connect D0 on the drive ?
I will use a gotek as external drive, should I modify anything ?
