stween's build
Re: stween's build
stween wrote: 18 Dec 2022 20:27 A quick check between festive tasks: with no glue, no CPU, address fc0000: DTACK is low.
Check DTACK resistance to 0v (with power off of course) something doesn't seem right there.
stween
Re: stween's build
Post by stween »
exxos wrote: 18 Dec 2022 21:42
Looks like 1k resistance to ground.
Re: stween's build
stween wrote: 19 Dec 2022 03:47 Looks like 1k resistance to ground.
Doesn't sound right. Should be open circuit really.
Not sure without looking , but remove the other chips which have dtack on them. Likely MMU, MFP, etc
stween
Re: stween's build
Post by stween »
exxos wrote: 19 Dec 2022 04:32
Mmm. Okay, I removed all chips I see DTACK on. I still see 1k to ground.
Not sure if this is relevant:
Decided to go fishing and look at resistance on adjacent pins to DTACK on each socket. Figured sharing the same path might be indicative of ... something. What I did so far is NOT AT ALL thorough because I didn't map the top of the socket to the grid layout on the back, but looking at immediately adjacent pins on the top of the sockets didn't show the same resistance as DTACK on any socket, except on the GLUE.
On GLUE: pins 28 through 33 show the same 1k resistance. That's: RDY, VPA, BERR, DTACK, IPL1, IPL2.
Re: stween's build
What does DTACK measure to 5v then ?
EDIT
With no chips on the board and unrelated signals.. I wonder if your aware of this fix ? viewtopic.php?f=89&t=5256
You could remove the inductors and see if those pins go high then...
There should be noting at all on DTACK.. Basically blitter, CPU, MMu,GLUE,68K sockets, MFP. 3.3V buffers.
Aside from RDY which isn't on the CPU.. The others are unrelated aside from the 3.3V buffers. and even then different ones!
stween
Re: stween's build
Post by stween »
exxos wrote: 20 Dec 2022 05:07 What does DTACK measure to 5v then ?
Just under 1k to 5V. (To ground is actually just over, like 1.1k. To 5V, it's 0.9k.)
DTACK is open circuit to ground from the 3.3V expansion slots; I figured those are separated off from the rest of the board anyway so forgot to mention.
I have definitely never seen this page before :) Replacing those might be beyond me and my tools though!
Re: stween's build
stween wrote: 20 Dec 2022 13:38 I have definitely never seen this page before :) Replacing those might be beyond me and my tools though!
Just blob them with a solder blob and they will ease off.. clean off the pads with braid. Not sure how the buffers will react, but cant make things any worse. In theory just the 3.3V bus won't work, but that's not important right now anyway.
stween
Re: stween's build
Post by stween »
exxos wrote: 20 Dec 2022 13:50
Okay. Specifically, just the highlighted resistor-shaped packages to the top left of each of the larger chips? (the bus converters?)
I can futz with it this evening. If not this evening ... then I'll probably have to park it until mid January/early February!
Re: stween's build
stween wrote: 20 Dec 2022 15:06 Okay. Specifically, just the highlighted resistor-shaped packages to the top left of each of the larger chips? (the bus converters?)
I removed them in this post.
viewtopic.php?p=87527#p87527
stween wrote: 20 Dec 2022 15:06 I can futz with it this evening. If not this evening ... then I'll probably have to park it until mid January/early February!
You cannot keep us in suspense that long :lol: :chairsmack:
Though if it is not those bus converters then I give up :lol: :roll:
stween
Re: stween's build
Post by stween »
exxos wrote: 20 Dec 2022 15:17
Useful, thanks!
haha I'll be away from home, that's the real problem! I probably have time tonight. I've just got the fear about components so small!
Return to “H5 C1 USER BUILDS”
