This thread is to track experiments to improve FPU stability on boards where it doesn't work out of the box.
e.g. adding extra capacitance, DSACK plumbing changes, FPU CS logic changes, clock changes, checking appropriate socket used etc!
DFB1 FPU experiment thread
frank.lukas
Re: DFB1 FPU experiment thread
I understand not (not an expert) why is it so complicated ...
Atari TT and PAK68/2 and PAK68/3 have no problem with a asynchronous Line-A FPU
PAK68/2 (csfpu = fc0 * fc1 * /a[19] * /a[18] * a[17] * /a[16] * /JP4 ;)
PAK68/3 ...
PAK 68/3, GAL U6: Adressdekoder, Atari ST
16-09-93 V6_STc1 Holger Zimmermann @ PE
May be use a 16V8 GAL to generate fpucs without the CPLD Firmware ?
PAK68/3 ...
___ ___
!vpa |1 24| VCC
fc0 |2 23| !jp3 Jumper J3: fpu_en
fc1 |3 22| !berr_20
!as_20 |4 21| !csp19
a21 |5 20| !rom
a20 |6 19| !fpucs
a17 |7 18| !word
a18 |8 17| !ciin
a16 |9 16| !dram
a19 |10 15| !avec
a22 |11 14| a23
GND |12 13| !berr_00
|________|
%ID
P6_ST
%TYP
GAL20V8A
%PINS
!vpa fc0 fc1 !as_20 a21 a20 a17 a18 a16 a19 a22
!berr_00 a23 !avec !dram !ciin !word !fpucs !rom !csp19
!berr_20 !jp3
%LOGIC
berr_20.OE = VCC;
berr_20 = as_20 * fc1 * fc0 * !a19 * !a17 'PMMU, BKPT
+ as_20 * fc1 * fc0 * !a19 * a17 * !jp3 'FPU disabled
+ as_20 * berr_00;
fpucs = fc1 * fc0 * !a19 * !a18 * a17 * !a16 * jp3; 'FPU enabled
avec = fc1 * fc0 * vpa;
csp19 = fc1 * fc0 * !a19;
dram = !fc0 * !a23 * !a22
+ !fc1 * !a23 * !a22;
rom = a23 * a22 * a21 * a20 * a19 * a18 * !a17 'TOS 1.04
+ a23 * a22 * a21 * a20 * a19 * a18 * !a16 'TOS 1.04
+ a23 * a22 * a21 * !a20 * !a19; 'TOS x.06
word = a23 * a22 * a21 * a20 * a19 * a18 * !a17
+ !fc0 * !a23 * !a22
!ciin = a23 * a22 * a21 * a20 * a19 * a18 * !a17 'ROM
+ a23 * a22 * a21 * a20 * a19 * a18 * !a16 'ROM
+ a23 * a22 * a21 * !a20 * !a19 'ROM
+ !fc0 * !a23 * !a22 'RAM
+ !fc1 * !a23 * !a22; 'RAM
%ENDMay be use a 16V8 GAL to generate fpucs without the CPLD Firmware ?
Neither do we Frank. That's kind of the problem...
foft
I do have a bunch of GALs (and FPGAs) around so can try that too.
I was thinking of starting with just popping FPU_CS, FPUCLK, AS, FPU_DSACKn, CPU_DSACKn onto the logic analyzer to take a look. It's probably going to be easier to do that (without disturbing signals) with a slower clock. I guess I can remove the oscillator and drive the clock from a pll in one of my FPGAs floating around...
I wish I had signaltap II on the CPLD!
Unfortunately, other tasks call for now, so I might not progress so rapidly! French class tonight, work christmas party tomorrow etc.
I've no idea yet of the problem. I added some extra capacitors onto the power rails under one of the FPU sockets, with no change.
I'm using these sockets, hope those are good:
https://multimedia.3m.com/mws/media/358 ... ts2148.pdf
In the past I've just jumperwired XCPUCLK from the Falcon to the OSC IN.foft wrote: 07 Dec 2022 20:29 I was thinking of starting with just popping FPU_CS, FPUCLK, AS, FPU_DSACKn, CPU_DSACKn onto the logic analyzer to take a look. It's probably going to be easier to do that (without disturbing signals) with a slower clock. I guess I can remove the oscillator and drive the clock from a pll in one of my FPGAs floating around...
Another option is to set OPTION2 (don't accelerate), remove R18 and join CPUCLK and FPUCLK to keep everything nicely in lockstep.
3M are probably the best generally available, so no drama there!
BTW, if you want a basic sanity check this is the fly-wire hack I mentioned to allow the onboard FPU socket to work. Obviously remove the external once first, but then you just need to jumper 030 DS to a pin on U62 (I use a protective resistor):
https://github.com/dh219/DFB/wiki/FPU#the-workaround
Your chips that fail some of the time can then be tested at 16MHz on the motherboard before being tested again at 16MHz on DFB1.
Rustynutt
For years have kept this image bookmarked, running into similar problems on the stock board and overclocking FPU's.
Be nice to test theory someday. Believe the company is called WARWICK or WINSLOW in the UK.
foft
Sorry I am still here and interested, just caught up with some other stuff! I'll get a chance to try this in the next week or so I think.
No worries. If you need any custom firmwares or want a hand modifying any of the verilog, I'll be eavesdropping :-)foft wrote: 12 Dec 2022 23:00 Sorry I am still here and interested, just caught up with some other stuff! I'll get a chance to try this in the next week or so I think.
@Badwolf I was just reading the MAXI030 blog (a small 030 based system, project) The author was also having difficulty getting the FPU working properly, he had put the decoding on the rising edge of the clock to fix it.
Perhaps some of the details on his blog might help with the DFB1?
https://www.aslak.net/index.php/2022/01 ... d-maxi030/
(Incidentally I also wonder how EmuTOS would perform on this system)
Cheers, Steve.
Interesting read. He's working around limitations in his combinational logic it seems, but the fact it work even with a late CS signal should suggest sensitivity here isn't an issue.
No hard in Foft giving the same approach a go with one of his failing boards, mind.
