Always seems to be
X,Y,W,H.
Huzzah!exxos wrote: 02 Dec 2022 22:08 So it may not like it but the menu was drawn over the top and then turned into a white square and then restored correctly :D
Yeah I am saying MINT and shouldn't be. @Badwolf sent me this all setup so no idea what it is really.Steve wrote: 06 Dec 2022 21:15 I guess when you mention MINT technically you should be saying XaAES since there are multiple different AES's you could be using which handle this issue independently. Perhaps you could try MyAES since the creator OL is very active and could give you good insight, you might also find a bug in XaAES and @mikro might be able to help with that.
Exactly.stephen_usher wrote: 08 Dec 2022 22:53 Given how long TOS takes to get to the memory test, even the slowest spinning rust drives would be fully spun up by the time the memory test finishes anyway.
:lolbig:stephen_usher wrote: 08 Dec 2022 22:53 (OK, maybe not some of the old Fujitsu Eagle 500MB IPI drives, they took 2 minutes and dimmed the lights whilst spinning up, but you couldn't connect those to an ST anyway.)
Users browsing this forum: apple [bot], ClaudeBot, gpt [bot], Icky, nicknm, simon.osborne and 8 guests
