Problem with installation NVDI 5 - disk 2
The place to ask all those likely daft questions!
arti040
Post by arti040 »
Hi,
I downloaded the archive from here -> https://exxosforum.co.uk/forum/download ... p?id=17529
It is divided to two folders - DISK1 and DISK2 but when I'm trying to install it it keep asking me for DISK 2 and stuck.
What am I doing wrong?
Re: Problem with installation NVDI 5 - disk 2
Not sure what page you got that from. But this one is already installed.
viewtopic.php?f=25&t=51
Also can you please not hot link to external hosting sites and upload images to the forum thanks :)
arti040
Post by arti040 »
Oh, thanks! :-)
arti040
Post by arti040 »
Well, now I'm getting this error... and surely I got a lot of space on boot drive (around 150MB) ->
I don't understand what you are doing..
It is literally set up already installed. I did all this so nobody has to mess around with the installer any more. All you have to do is copy the files onto your hard drive and that is it.. You should not be trying to be installing anything.
1) EXTRACT ARCHIVE
2) COPY FILE TO HARD DRIVE
3) DONE!
arti040
Post by arti040 »
First I grabbed the installer. Now I took your ready-to-use archive and it worked. But failing installer is interesting though...
I don't remember the installer problems. But maybe there was 2 files for disk 1 and disk 2 which needed to be in root. I remember I had to fix many file errors in the installers I found, I don't think I really kept the installer files..maybe..but was pointless as would only install the files in my installed copy anyway.
I guess a self extracting zip would do the same as a installer, but really no need I think anyway.
frank.lukas
Post by frank.lukas »
arti040 wrote: 27 Nov 2022 21:15 It is divided to two folders - DISK1 and DISK2 but when I'm trying to install it it keep asking me for DISK 2 and stuck.
Copy all the files from the two disks to a folder on the hard drive and delete the nextdisk file and run the installer ...
arti040
Post by arti040 »
<3
Return to “NOOB QUESTIONS”
Users browsing this forum: Baidu [Spider], ClaudeBot and 7 guests
