dml wrote: Mon Nov 14, 2022 11:12 am
It's a one-shot error every 8kb, with a fixed (weird) offset, bit #11 of 32. Which is a very strange result but still some sort of clue
Absolutely. There are probably 2 address bits that play here in conjunction with a bad bit 11.
You would think that if noise on bit 11 blew the chip, it would blow it across the entire address range. But there must be some sort of pattern going on relating to address ranges.
The other guy who had a problem had this..
- IMG_5791.jpg (108.07 KiB) Viewed 1089 times
Of course I don't know the actual failure mode of the DRAM either. even though there is some sort of alignment going or some sort of consistency. I think overall the address ranges and bit failures are seemingly just random.
The data bits could be physically picking up "noise" from certain address lines aggravating the problem. Or maybe the Videl itself as internal glitches which are basically random.
There must be some sort of bus noise going on because again when the DFB1 Is plugged in the faults seem to be reduced. Really have no idea what the internal routing is like on these motherboards. Even though we seem to go from CPU <> Videl <> RAM, other traces all over the place which could couple noise on adjacent tracks causing the spikes on the DRAM databus.
Again it could possibly be the Videl itself causing the problems as it is literally connected to CPU and RAM. so greater activity on the CPU could create different noise in the Videl internally which then couples onto its DRAM bus. Of course it is just speculation but these spikes have to be what is killing the DRAM and something has to be generating them.
I guess I could run GB6 on various tests to see if there is any correlation between the test and spikes on the DRAM bus..
