exxos wrote: Tue Nov 22, 2022 12:29 am
@rubber_jonnie sounds odd the 12v drifting like that. Regulation is probably only on the 5v side . so if 5v never rises like the 12v then it rules out a lot of stuff. It almost impossible for the 12v to drift on its own.
The diode pack will have 2 inputs back to the tranforimer winding, trace those back and see if there's a center tap on the transformer. Either way, measure the coil resistance when its cold, and outputting low voltage. Then let it warm up and measure the coil resistance to see how much its drifting by. I would repeat on the 5v winding as well as a frame of reference.
I'll take a look thanks.
Also check the diodes inputs and outputs on your scope. Cold and when warmed up. See what the voltages are like.
I will, but running out of time this week for various reasons, and away next week Monday-Wednesday for Dads funeral
Also not easy to get a probe on them from the topside due to other components being in the way, so I need to figure out something that doesn't end up shorting stuff out or giving me a shock.
There isn't much to them really. Indeed you can get a idea from the MSTE PSU schematic on now things are wired up.
I'm wondering really if the transformer core has a partial internal short circuit. Hence measuring voltages and resistances on it.
I guess it could be, I will see if I can do some testing this week.
Also does the 12v drop under load either hot or cold ?
Ok, so I just did a cold start off load and got: -3.64v, 5.35v and 12.6v.
On load (Mainboard, HDD and FDD connected), cold, 12V started low (10.2v) and jumped up to 12.15v within about 5 seconds. Machine booted and drive spun up just fine within 30 seconds. 5v started at about 4.8/4.9v and eventually settled at bang on 5v. Machine booted just fine. -5v was settled at -4.85v.
I'm going to leave it for an hour or so, make sure it's 100% cold and all caps discharged, then I will try again.
Top of PSU:
- PXL_20221122_084628322.jpg (386.3 KiB) Viewed 1252 times
Bottom of PSU (Flipped horizontally - left end of PCB = right end of topside):
- PXL_20221122_085041687.jpg (333.71 KiB) Viewed 1252 times
The messy area of darker green is an earlier repair for the 7905 which had clearly been knocked and the pads loose under the board. It is not a quality PCB, that's for sure.
And here are the areas of interest:
- Separation.jpg (358.66 KiB) Viewed 1252 times
Red=mains side
Blue=low voltage side
Pale blue=5v
White=12v
Brown=GND
Yellow=transformer connections from high to low voltage side
Purple=2xDiode packs and 1xSCR attached to the large heatsink marked 'Front'. (From the bottom up - SCR, TIC126M, new item replaced with same, Main diode pack, SLP2040P replaced with MUR3040PT and FEP16CT replaced with new MUR2045CT)
The Mains side has a K1117 switching transistor on the smaller heatsink on the other side of the transformer when viewed from above, this has also been replaced with an identical new one.
From what I can determine from the PCB and topside, there is a switching section on the high voltage side that goes through the transformer where it's rectified by the 3 components on the large heatsink.
Incidentally, whilst the -5V line has a 7905 regulator, the 5v side has no regulator so must be derived from 12v somewhere, or maybe directly rectified from the transformer.
