A little bit of 8 Bit: 65XE upgrade to 128k RAM
Hoping nobody minds, especially since we are predominantly 16 Bit, but having just completed a successful upgrade of my 65XE from 64k to 128k, I know how difficult it was to source the parts, so I wanted to share with everybody.
The parts needed are:
1x 20 pin DIL socket for the MMU chip
8x 16 pin DIL socket for the RAM chips
8x 1uF ceramic capacitors
1x Atari C25953 MMU (Search eBay for "NEW Atari computer 16 DIP IC 130XE 65XE 65 130 XE C25953-20 EMMU memory IC chip")
8x RAM chips (Search eBay for "8x MB8264A-15, 64Kx1-bit NMOS Dynamic RAM-NEW", a guy in Bulgaria is selling and has some left)
Your 65XE will need to be one that has the slots free for the additional memory, or this won't work.
Once completed, find a 128k demo, such as the Space Harrier Demo (This is really cool!), and if everything is ok, then your 128k software will run.
Mine worked first time, but if it doesn't work for you, I suggest a magnifying glass to make sure there are no solder whiskers bridging pads, and that all the chips are nicely seated.
If it doesn't work first time, provided you've used sockets, then you can remove the chips and check it's all good without.
Re: A little bit of 8 Bit: 65XE upgrade to 128k RAM
Hi,
If you want... I make another solution - cheaper and same effort, but you will get 320 KB RAM
You need:
8x 41256 DRAMs
1x resistor 33 Ohm
1x GAL 16V8 DIP
1x 74LS95
Insert the 8 DRAMs (you can get them cheap on eBay or you buy an Amiga 500 memory expansion for less then 10 USD/Pound/Euros which contains such DRAMs often and rip off the chips). Bent pin 1´s of the 8 DRAMs up OR connect unused pads for pin 1 of the sockets. You don´t need the CO25953, the GAL will do this job.
Here´s the GAL source listing:
The LS7495 must be placed at the positon of U35. The GAL - bent pin 7, 8, 9,12 and 13 up - will be placed in U34. Connect pin 7 of the GAL to pin 16 of PIA and pin 8 of the GAL to pin 17 of PIA. Pin 9 can be left open (expansion enabled) or closed by switch to ground to disabled the expansion. Pin 12 via 33 Ohm resistor to the pin 1´s of the 8 DRAMs (memory addressline A8) and pin 13 to the pin 6 of MMU. This pin must be also bended, so better is to desolder the MMU, fit it into a socket and replace it with pin 6 bend up.
I make several years ago an article for the ABBUC magazine no. 95. You can download it here, but the text is only in german - sorry.
Jurgen
Nice solution - well done!rubber_jonnie wrote: Thu Aug 31, 2017 12:40 am Hoping nobody minds, especially since we are predominantly 16 Bit, but having just completed a successful upgrade of my 65XE from 64k to 128k, I know how difficult it was to source the parts, I wanted to share with everybody.
You need:
8x 41256 DRAMs
1x resistor 33 Ohm
1x GAL 16V8 DIP
1x 74LS95
CHIP XE_320k GAL16V8 SIMPLE_MODE
A14 A15 pb2 pb3 pb4 cas pb6 pb7 mode GND
mhalt ra8 map casbank casmain fa_14 fa_15 pb5 phi2 VCC
fa_15 = A15
+ A14 & pb3 & /pb4 & mode & mhalt
+ A14 & pb3 & /pb5 & mode & /mhalt;
/fa_14 = /A14
+ /A15 & /pb2 & /pb4 & mode & mhalt
+ /A15 & /pb2 & /pb5 & mode & /mhalt;
casmain = /phi2
+ cas
+ /A15 & A14 & /pb4 & mode & mhalt
+ /A15 & A14 & /pb5 & mode & /mhalt;
/casbank = /A15 & A14 & phi2 & /pb4 & /cas & mode & mhalt
+ /A15 & A14 & phi2 & /pb5 & /cas & mode & /mhalt;
/map = pb4 & pb5 & /pb7;
ra8 = /phi2 & pb6 & mode
+ phi2 & pb7 & mode;I make several years ago an article for the ABBUC magazine no. 95. You can download it here, but the text is only in german - sorry.
Jurgen
- Attachments
- 320 KB for Atari XE.zip
- German article with pictures of ABBUC magazine 95
- (916.2 KiB) Downloaded 707 times
- 800XE320.zip
- JEDEC file for 16V8 GAL
- (438 Bytes) Downloaded 608 times
Cool, nice one
A little more complex to do, but very nice result.
Well done to both
Here is the finished article, reassembled post 128k upgrade and with a case and keyboard clean.
Looking good for over 30 years old.
*envy mode on*rubber_jonnie wrote: Mon Sep 04, 2017 5:22 pm Here is the finished article, reassembled post 128k upgrade and with a case and keyboard clean.
redhawk668
I’ve done a 320 kb upgrade on a 130XE, I had to desolder the second bank of ram chips. My solution uses a 74LS158, a 33 ohm resistor and some wire. I used the 256 kb drams from a dead Atari ST.
My collection: 1040 STE, TOS 2.06, 4 mb, CosmosEx - 520 STFM, TOS 1.04, 4 mb, Blitter, CosmosEx - 520 STFM, TOS 1.04, 4 mb - 1040 STF, TOS 1.04, 1 mb, Gotek - Amiga 1200 with Blizzard 1220/4 - Amiga 500 + ACA500 - Amiga 500 + TF530, 1 mb chipram hack.
Atari 8 bit: 800XLF, stock - 600XL, Ultimate 1 mb, Sophia RGB - 130XE, 320 kb, Sophia RGB
Sinclair stuff: 3x Spectrum 48KB, Clones: Harlequin, JS128, Nuvo128 and Issue3B replica.
Ultimate64, a few C64 breadbins and Pi1541 for storage.
Nice to see some 130XE love. Mine is sitting between a A1200 and a Falcon and I have one more to fix. When I got my 800XL the 130XE popped along not long after and I would go all giddy looking at photos of it, same as I did for the Falcon. Say what you will, Jack Tramiel new styling.
Any chance of some pics and details?redhawk668 wrote: Fri Feb 23, 2018 6:30 pm I’ve done a 320 kb upgrade on a 130XE, I had to desolder the second bank of ram chips. My solution uses a 74LS158, a 33 ohm resistor and some wire. I used the 256 kb drams from a dead Atari ST.
walter_j64bit
A 65XE to 128k nice work! I would love to see 65XE to 256K.
