Copy hard drive data
digitalman
Wondering if anyone has a good solution for copying data off an internal SCSI drive. I want to take my physical drive data and move it to an SD card (clone/backup). I do not have any PCs with SCSI. I do have a NetUSBee and could essentially download each and every file, but that would take forever. Is there an FTP client for Atari?
Re: Copy hard drive data
The latest UIPtool has an FTP server built in I believe, so you could use that in combination with the NetUSBee.
https://bitbucket.org/sqward/uip-tools/src/master/
digitalman
Indeed it does! This should do the trick, thanks!
digitalman
So I have run into a couple if weird problems with this.
1) Directory listings on the FTP client side (pc side) shows weird names. For example, on the Atari the directory is UTILS, but on the PC it shows; MAY 0 1981 UTILS. If I go into it, the directory is empty. But if I CD UTILS I get a directory with files, and similar names again. All files are preceded with a date. Makes transfers very difficult. *no wild cards"
2) One directory just crashes the uIP tool when you do a DIR on it. Must be a file name in there it can't handle.
Any other ideas?
Any other ideas?
digitalman
I found this FTP app for ST. So far so good!! Slow..but it's doing the trick.
https://ptonthat.fr/litchi/
