TF536 to 68000 switch
68030 + SDRAM + IDE
simon_m74
Post by simon_m74 »
odd question.
As the CD A570 will not boot with the TF536. Is it possible to put a 68000 in there as well (on a custom PCB - to have 68000 & TF board) and switch between the 2, by switching gnd and power between the CPUS ?
derkom
Re: TF536 to 68000 switch
Post by derkom »
It takes a bit more than GND and VCC. There's a switcher called "garlic" that will do what you need, posted here.
Edit: Although now that I reread your post, it sounds like maybe you're wanting to switch CPUs on-the-fly, i.e. after booting the 68000? That is not possible.
amimjf
Post by amimjf »
Hi,
Have you considered patching the A570 extended ROM so it works with the TF536 ?, see..
https://cdtvland.com/os235/
https://github.com/C4ptFuture/cdtv-os235patch
This is definitely a software issue and not a hardware issue. Try the alpha version (98-114-a570) of Extended ROM v2.35 for A570 and it should solve your issues.
The A570 version is AFAIK only available on the Discord channel.
8 Bit Dreams
Moderator Team
Moderator Team
Post by 8 Bit Dreams »
A570 ROMs wasn't released yet, please be patient :idea:
If you want to test it you can request to join the Discord and the alpha version is available for download.
Return to “TF536”
