PSU bracket remake ?
sandord
Re: PSU bracket remake ?
Post by sandord »
Forgottenmyname wrote: Wed Aug 22, 2018 2:00 pm can give you an estimate of print time and cost by loading the .stl into Cura? And when my workshop is no longer "upside down" would be happy to try printing it?
The current model takes 04h 04min on my printer, Cura says.
Thats not too bad and can be printed at lower quality settings as the "finish" is not as important as strength.
sandord wrote: Sun Aug 26, 2018 4:38 pm I printed a leg and a small part of the bracket to try out whether this works.
Well, I'm quite pleased so far.
Impressive stuff!
Was there any more progress with this project ?
sandord
Post by sandord »
exxos wrote: Sat Sep 15, 2018 9:19 am Was there any more progress with this project ?
It's been on my mind all the time but had priorities elsewhere. I'll try to do a complete print job in the next few days so I can try to fit it in a real ST.
Once that's done and no spacing problems remain, I can work on model strength and other optimisations (use less filament by adding meshes etc.)
So, at that stage the thing should still work with an original psu, which I think is a good thing even though most future applications will be with psu remakes, I think? Having both just seems nice and it's easy to stay compatible.
sandord wrote: Sat Sep 15, 2018 9:32 am So, at that stage the thing should still work with an original psu, which I think is a good thing even though most future applications will be with psu remakes, I think? Having both just seems nice and it's easy to stay compatible.
Keeping the design original is good as it fits anything then (almost) . Likely main use is new PSU builds I think though. I am not sure how many people would need to or want to fit a plastic base for a PSU.
troed
Post by troed »
When you're done I'll print this as well (Ultimake 2) and verify with one of many PSUs laying around here. I have M3 nuts and bolts already.
Good remake of the original metal design into something more suitable for 3D printing!
sandord
Post by sandord »
Did a little work on it today, front legs are finished now, added a mesh for additional strength (could be left as an option).
So basically only the two rear legs remain, besides the refinements that of course will come as a result of testing an actual print.
sandord
Post by sandord »
troed wrote: Sat Sep 15, 2018 10:24 am When you're done I'll print this as well (Ultimake 2) and verify with one of many PSUs laying around here. I have M3 nuts and bolts already.
That'd be great! I'm using tooth lock washers as well, see earlier pictures of my first trial prints of one of the legs. I'm not sure if they are absolutely necessary but they provide additional grip on the plastic and when tightening the bolt, not all force is transferred to the plastic, rather to the washer compressing a bit.
Looks great to me. I can run a copy off to if you wish?
