Review hard disk options for STM & STFM?
- frank.lukas
Re: Review hard disk options for STM & STFM?
Lightning ST for DIL 68k CPU typ Computer have IDE and USB ...
https://wiki.newtosworld.de/index.php?t ... ghtning_ST
I'm not entirely sure why you'd want to use an SSD, though I know it's a question that's often asked.
I suppose that you could put an M2 SSD into a USB caddy, hook it up to a NetUSBee with a driver and try to format/partition it. Not sure why you'd want to do that, but you could.
- olivier.jan
SSD should work with an IDE adapter, but it’s not going to give better results than an SD card, here the ST is the bottleneck, not the disk.
Be careful also, obviously TOS or the driver will not have any specific SSD management routines like modern OSs and this might impact the lifespan of your SSD.
Retro stuff
- Atari74user
Yeah, I think very valid points, I don't think there is any overwhelming benefit of an SSD in an ST, Falcon less so given it already has an IDE and it can be a tidy option if nothing else, but still... some nice options these days!
AtariTOSser
Medusa Hades 060 512mb, ET4000 / MACH64 | Atari Falcon 14mb, 68882, 8gb CF, Steinberg FDI, FA8, GigaFile & CT60e | Atari Jaguar, GD, Skunkboard & Cat Box | Atari 520STFM 4mb, Exxos Booster, TOS switcher, OverScan, UltraSatan, PARCP-USB, Unicorn-USB, ICD Link 2, ADAP, ADAP II, Lynex, ADAS-ST, SoundPool MO4, Steinberg MIDEX, SMPII, Emagic Log 3, C-Lab Unitor 2, Combiner & ExPort...
Hi. Yeah, it wasn't me - one of the users on my BBS was inquiring about it.rubber_jonnie wrote: Sat Jul 09, 2022 10:07 pm
Personally, I'm quite happy with the internal Ultrasatan's in my Mega STe
and STacy and I have the Lightning ST setup in the Mega ST4 that runs my
BBS.
We've all seen this a lot - there's a perfectly fine, working, known, stable
solution for something and yet there will always be someone out there who
will want to go off in another direction...
It's all good.
Thanks. I actually have the Lightning ST installed in my Mega ST4,frank.lukas wrote: Sat Jul 09, 2022 9:50 pm Lightning ST for DIL 68k CPU typ Computer have IDE and USB ...
but have the IDE side disabled.
I just didn't need that part of it...
So I'm going to advise the user who asked this question on
my BBS, that...it's "do-able" but probably not recommended
since there are solutions that are easier to implement and
probably better suited for the ST.
Thanks all!
Thanks all!
It’s a bit like asking if you could fit a lorry engine onto a Mini. Technically yes but what’s the point?
It's definitely one of those 'well you could, but should you' moments.Darklord wrote: Sat Jul 09, 2022 11:44 pm So I'm going to advise the user who asked this question on
Thanks all!![]()
As others have said, there is no performance gain to be had as the ST is the bottleneck, then you have IDE to SSD adapters in the mix which are additional connections that could fail.
SD cards are more than good enough in most scenarios. I use a mix of SD cards (CosmosEx and Ultrasatan) and CF cards where I have added IDE interfaces. I possibly even have a real 2.5" hard disk in one of my Megas.
All of them perform just fine.
