Falcon - NO VIDEO SIGNAL
marss
Post by marss »
Hi,
The Falcon is powered (LED shines, Fan of the CT060 turning, HDD working) but NO VIDEO SIGNAL ;(
What could be wrong?
Please help.
Marss
kodak80
Re: Falcon - NO VIDEO SIGNAL
Post by kodak80 »
What happens if you push the reset button?
You really should do some troubleshooting yourself before asking on the forum. The first thing is a no brainer, remove the ct60 and any add on cards then try.
marss
Post by marss »
Nothing happens when the reset button is pushed. Still NO VIDEO SIGNAL
marss
Post by marss »
and the CT060 was removed
Tried RGB & scart ? was it ever working ?
Mostly machines end up coming to me for repair when this happens otherwise, either blown 12V line somewhere, or blown videl/codec chip.
marss
Post by marss »
Tried RGB and SCART... no luck
Could it be that the orange thread from the PSU touching the inside of one of the white plastic connection be the cause? if so, what could be the consequence. If still problem, so Exxos will be happy to repair it ;)
marss wrote: Sun Aug 26, 2018 9:28 am Tried RGB and SCART... no luck
Check your PSU has 12V output.. you should also check you have 12V power to the video DAC chip. I have seen a lot of power issues on a lot of falcons.. seems like tracks burn out :roll: I've seen a lot of blown videl's in Falcons over the past 2 years, I can't really prove it yet, but I think its bad PSU's blowing the chip up. Its why I suggest people re-cap their PSU's and don't use picos.
Posible I could repair it, but I send off to another company to change chips now, I'm to old for all that stuff.. but I have that much repair work to get though and no time to do it all.. probably be next year before I can catch up.
calimero
Post by calimero »
I must ask:
Why to not use Pico PSU?!
@marss
If you have black screen maybe RAM is problem.
using Atari since 1986.http://wet.atari.orghttp://milan.kovac.cc/atari/software/ ・ Atari Falcon030/CT63/SV ・ Atari STe ・ Atari Mega4/MegaFile30/SM124 ・ Amiga 1200/PPC ・ Amiga 500 ・ C64 ・ ZX Spectrum ・ RPi ・ MagiC! ・ MiNT 1.18 ・ OS X
marss
Post by marss »
@calimero... RAM... It was removed and back, but no result ;(
