Steve wrote: Mon Jun 20, 2022 5:04 pm
Markus608 wrote: Mon Jun 20, 2022 3:52 pm
Anyways...
i still have the problem that it starts to desktop.
Floppy isn't working, so i can't start any HD-Driver from desktop.
Do i need to use a different IDE-cable... maybe with some wires twisted or something ?
If i can't get it working i'll try to use CPU and FPU in another accelerator...
Markus only way around it is that you create a drive image in Hatari, put hd-driver on it, then write it to your CF card. In regards to the IDE cable stuff, agranlund details it quite thoroughly in his thread I think. But from what the others here say, it probably isn't worth the effort.
@Markus608, the IDE port pinout is different on Amiga vs Atari.
I used a modified cable on mine and I believe I detailed it on some thread like
@Steve mentioned.
(You'll have the same issue on the TF536r2 as well - but the ST version probably works out of the box? I think?)
Eventually ended up making an adapter PCB and the whole thing looked like this:
- IMG_6245.png (189.13 KiB) Viewed 3321 times
- IMG_6250.png (157.8 KiB) Viewed 3321 times
I already had my CF card prepared since the previous IDE interface so I never had a reason to boot from a floppy.
Don't know if it makes a difference or not but my card had a bunch of partitions that were all TOS 1.04 compatible (<512MB and no Tos/Win dual compatibility mumbojumbo
I feel like I should explain some of the reasons why I was so happy with these cards..
My expectations where all based on it being made by someone in their spare time, primarily for a different computer, and released to the public completely for free - that it ended up working as well as it did was great in my book.
A lot (most?) of the enjoyment for me came from tinkering and making things work. If this had been a piece of tech from the store where you'd want and expect everything to just work out of the box then I'm sure I probably would have had a different reaction
I'll second the opinion of exxos and terriblefire. Anyone considering a TF53x for the Atari should get the TF536-ST version.
You'll get something specifically made for the machine and support the exxos store while at it so it's a bit of a win-win really.
Saying that, if you already have an older 534 or 536 then I don't see any reason to throw them in the bin. I think both of these has worked really well in my computer.
