I have some Apple mice, original single button ADB and they don't fit, though I have a number of different variations so I will look see if any are smaller.stephen_usher wrote: Thu May 26, 2022 3:49 pm I think the mouse balls are the same size as the Mk.I Apple ADB bus mouse.
Apparently the mice were made by Logitech (even the original ones), so blame them for the self destructing gobstoppers!![]()
A5000 - diving in at the deep end!
Re: A5000 - diving in at the deep end!
It seems to be, yes.
Does that make it a Type 1 mouse?
https://chrisacorns.computinghistory.or ... .html#Mice
I thought A5000's shipped with a Type 3 mouse which are 22mm?
Looking on-line it seems that the A5000 shipped with the original mouse. The first one to have this mouse, which uses a standard mouse ball size, was the A4000...
Mine is a Type 1 mouse, yes. I have no idea if it originally shipped with it or if it was one that came along later.alexh wrote: Thu May 26, 2022 4:35 pm Does that make it a Type 1 mouse?
Annoyingly, I just found a really old mouse and the ball is quite small. Not small enough though, 21mm
- mrbombermillzy
I feel your pain
Lets see how the steel ball works out. I will try to find a small balled mouse when I can get to them.
Its a shame, as I got rid of several PC Serial/MS mice a while ago which I wouldnt of minded..er..castrating?!..is that the right term for it? (technically I would have been removing their balls, after all)
My main worry is that whatever ball I put in,, the rollers are a bit slick and shiny so might slip,, but let's see once the steel and Delrin balls arrive.mrbombermillzy wrote: Thu May 26, 2022 7:16 pmI feel your pain![]()
Its a shame, as I got rid of several PC Serial/MS mice a while ago which I wouldnt of minded..er..castrating?!..is that the right term for it? (technically I would have been removing their balls, after all)![]()
How big are real gobstoppers? I'm sure they'll grip if they get a bit sticky.
Buy a really big one and keep sucking till it fits!stephen_usher wrote: Thu May 26, 2022 9:03 pm How big are real gobstoppers? I'm sure they'll grip if they get a bit sticky.![]()
Probably!!stephen_usher wrote: Thu May 26, 2022 9:03 pm How big are real gobstoppers? I'm sure they'll grip if they get a bit sticky.![]()
