Seems I've looked at this before https://www.exxosforum.co.uk/forum/viewt ... 200#p31163
Seems just emulating the switches isn't enough. Looks like I was considering the register isn't even checked unless its found to be a STE based machine :roll:
:lol: yep it's confused things as most docs just state the joystick stuff :roll:sporniket wrote: 25 May 2022 03:20 if there is no error, info-coach hints at $FF9200 (see https://info-coach.fr/atari/hardware/ST ... #joysticks )
edit : ha, you posted while I was re-reading info-coach :D
; JED2EQN -- JEDEC file to Boolean Equations disassembler (Version V063)
; Copyright (c) National Semiconductor Corporation 1990-1993
; Disassembled from MSTE_UA2.JED. Date: 5-25-122
;$GALMODE MEDIUM
chip MSTE_UA2 GAL20V8
; note the inversion on A15 in the declaration
A4=1 A5=2 A6=3 A7=4 A8=5 A9=6 A10=7 A11=8 A12=9 A13=10 A14=11 GND=12
/A15=13 i14=14 o15=15 f16=16 o17=17 o18=18 f19=19 A2=20 A3=21
o22=22 i23=23 VCC=24
@ues 4d53544520554132
@ptd unused
equations
; "DD/HD mode on MegaSTE at $FF860E (bits 0/1)" (Hatari)
; The 22V10 is what decodes bit 0/1, but this PAL should decode that address I thought.
; an AND gate ands A16-A23 together as XIO which also goes to the PAL22V10
; we assume all those need to be 1's
; it also uses FC0, FC1 and FC2 where FC2 always need to be 1 but the others can be 1/0 or 0/1
; the "unconnected" pin 19 need to be grounded for some reason
; this is the output that should decode ff860e
; 1111111110000110000011xx = 0xff860c/0xff860e <-- what we have
; 11111111100001100000111x = 0xff860e <-- what we should have
/o22 = /A5 * /A4 * /A6 * i23 * /A7 * A3 * /A8 * A2 * A9 * f19 * A10
* /A11 * /A12 * f16 * /A13 * /i14 * /A14 * /A15
+ /A5 * /A4 * /A6 * /i23 * /A7 * A3 * /A8 * A2 * A9 * f19 * A10
* /A11 * /A12 * f16 * /A13 * i14 * /A14 * /A15
o22.oe = vcc
/A3 = gnd
A3.oe = gnd
/A2 = gnd
A2.oe = gnd
/f19 = gnd
f19.oe = gnd
; this should be fc0dxx?
; 111111111100001xxxxxxxxx = 0xffc2xx-0xffc3xx
/o18 = /i23 * /A9 * A10 * A11 * A12 * f16 * A13 * i14 * A14 * /A15
+ i23 * /A9 * A10 * A11 * A12 * f16 * A13 * /i14 * A14 * /A15
o18.oe = vcc
; this should be ff8e20?
; 111111111000110000x000xx (A5 not used) = ff8c00-03 & ff8c20-23
/o17 = i2 * /A4 * /A6 * i23 * /A7 * /A3 * /A8 * /A2 * /A9 * A10 * A11
+ i2 * /A4 * /A6 * /i23 * /A7 * /A3 * /A8 * /A2 * /A9 * A10 * A11
o17.oe = vcc
/f16 = gnd
f16.oe = gnd
; "XSCC"
; 111111111000110010000xxx = ff8c80-87
/o15 = /A5 * /A4 * /A6 * i23 * A7 * /A3 * /A8 * /A9 * A10 * A11 * /A12
+ /A5 * /A4 * /A6 * /i23 * A7 * /A3 * /A8 * /A9 * A10 * A11 * /A12
o15.oe = vcc
Just a few lines above the code you posted earlier it checks an internal "STEFlag" variable to determine if it should read those dip switches or not :)exxos wrote: 25 May 2022 03:26 I guess the idea currently is that because its not a STE, TOS never looks at those addresses, and never checks the dip switches. So I need to look at where in TOS the joystick stuff gets enabled.
move.b #$7f,d0 **** put default dip settings in D0 (0x7f == DIP switch 6 is 1 == no HD Floppy)
tst.b STEFlag **** Is it an STE?
bne.s cooSTE **** no it's not, skip to cooSTE without reading dip switches
move.w (STConfig).w,d0 **** We are an STE. Read the actual dip switches from STConfig (0xFF9200) into D0
lsr.w #8,d0
cooSTE:
btst #6,d0 **** test bit 6 of D0 which is dip switch 6 (or always 1 in the case of non-STE)
bne.s cooFDC /* (punt - no HD floppy) */
move.b #8,dsb /* select HD density for drive A */
move.l #'_FDC',(a0)+ /* setup FDC cookie: Floppy disk controller */
move.l #$01415443,(a0)+ /* 'ATC' | (1 << 24) */
cooFDC:
That's what I thought originally but just ignoring this check made it work..https://www.exxosforum.co.uk/forum/viewt ... 575#p85575agranlund wrote: 25 May 2022 15:12 Just a few lines above the code you posted earlier it checks an internal "STEFlag" variable to determine if it should read those dip switches or not :)]
Nice one!exxos wrote: 25 May 2022 15:28 That's what I thought originally but just ignoring this check made it work..https://www.exxosforum.co.uk/forum/viewt ... 575#p85575
Users browsing this forum: ClaudeBot and 14 guests
