Xilinx programming cable USB -- anyone got this one?
I've been trying to help Frank get his Xilinx programmer working so we can try to work on some trouble he's having with his DFB1.
He's got a knock-off programming cable labelled as DLC9LP and with the following in lsusb:-
Bus 001 Device 008: ID 03fd:000f Xilinx, Inc.
Now 03fd/000f isn't listed in my copy of xc3prog, but we've tried setting it up as "xpc" (as that was the closest with 03fd/0008) via a cables database text file to no avail.
Does anyone have one of these matching these VIP/PID settings & know how to get it to work?
Ta,
czietz
Re: Xilinx programming cable USB -- anyone got this one?
Post by czietz »
This post indicates that 03fd:000f is one of the PIDs the cable can have when it expects the user to load the firmware to the cable:
https://github.com/timvideos/litex-buil ... nder-Linux
Elethiomel
Post by Elethiomel »
If you can't get stuff working, using a raspberry pi with a few jumper cables has worked very well for me
https://linuxjedi.co.uk/2021/11/25/revi ... pberry-pi/
frank.lukas
Post by frank.lukas »
Problem is I have not a pi and my PC had win7 and Ubuntu 15.04 on it. I can not install xc3sprog onto Linux because I can not upgrade to a newer version the PC is a 32bit one. So I must work with windows 7 ...
czietz wrote: 13 May 2022 20:46 This post indicates that 03fd:000f is one of the PIDs the cable can have when it expects the user to load the firmware to the cable:
Oh my word!
Thanks, Christian. That looks an absolute pain.
frank.lukas wrote: 13 May 2022 21:25 Problem is I have not a pi and my PC had win7 and Ubuntu 15.04 on it. I can not install xc3sprog onto Linux because I can not upgrade to a newer version the PC is a 32bit one. So I must work with windows 7 ...
Looking at the instructions Christian posted, it might be easier, quicker and cheaper to get a Pi ZeroW!
troed
Post by troed »
This is what mine presented before it had been initialized (firmware uploaded? Don't remember).
Wasn't a big deal to sort out.
czietz
Post by czietz »
Badwolf wrote: 13 May 2022 22:26 Thanks, Christian. That looks an absolute pain.
Hm, isn't it just one single command ("fxload ...") that Frank needs to run to load the firmware into the cable?
Badwolf wrote: 13 May 2022 22:27 Looking at the instructions Christian posted, it might be easier, quicker and cheaper to get a Pi ZeroW!
Looking at the worldwide(!) availability (or rather: non-availability) of Pi Zeros I doubt that: https://rpilocator.com/?cat=PIZERO
czietz wrote: 14 May 2022 08:23 Looking at the worldwide(!) availability (or rather: non-availability) of Pi Zeros I doubt that: https://rpilocator.com/?cat=PIZERO
Only if you buy new, I'm sure Frank could find one in local ads like Facebook market or Gumtree. There are *lots* of people who purchased a Pi for a project but never used it.
frank.lukas
When WIN7 boots, the red status LED on the USB cable lights up. I installed Labtool and the USB cable is recognized there, there is no message that it was not found, so I assume that it is recognized. But there is an error message that UREF is not there. I think I killed the USB cable at the very beginning because it also smelled like burnt electronics.
What is the exact way of proceeding when flashing?
A Rasp Pi is too expensive for me. I bought a USB CJMCU FT232H module and am trying it. Otherwise I have to send my Falcon mainboard plus DFB1 to England.
