ATARI 1040 STe black RGB good Composite
zChris
Re: ATARI 1040 STe black RGB good Composite
Opps i mixed the two signals. It's the Horizontal signal that's the bottom picture. The Horizontal at the chips seems correct though, i'll see if i can get a picture.
I can see you measured the 50Hz v-sync signal, but did you measure the h-sync signal, and if so, what was it?zChris wrote: 04 May 2022 20:44 Opps i mixed the two signals. It's the Horizontal signal that's the bottom picture. The Horizontal at the chips seems correct though, i'll see if i can get a picture.
zChris
Solved! It was the resistor that has somehow broken. Nothing that i can see visually though. but when i bodge over the resistor for Horizontal i get a picture :)
:bravo:zChris wrote: 04 May 2022 21:14 Solved! It was the resistor that has somehow broken. Nothing that i can see visually though. but when i bodge over the resistor for Horizontal i get a picture :)
What resistor are you referring to exactly ? IIRC there are no resistors on V&H sync ?
zChris
This is the resistor om talking about:
since the ohm is so small i'm thinking on just having a wire there instead :?
Users browsing this forum: ClaudeBot, semrush [bot] and 8 guests
