Making a start on @gebes H5C1 build
Re: Making a start on @gebes H5C1 build
@JezC they are separate. @rubber_jonnie did make an stl for those a while back.
@JezC You're welcome: https://www.thingiverse.com/thing:3219623PhilC wrote: 02 May 2022 11:08 @JezC they are separate. @rubber_jonnie did make an stl for those a while back.
Whilst on the subject of the FDD stand offs, I note that at least one in the pic is upside down, the slots are supposed to be at the bottom to click into the hole in the PCB like the originals, however I'm not sure if the holes on the H5C1 match the original PCB diameter, in which case it matters not :)PhilC wrote: 13 Apr 2022 19:44 So we’ve had a bit of a pause whilst installing the upgrades for @gebes’s H5 due to me being busy with work but yesterday the X2GS board arrived and is now fitted. The 3.3v bus resistor mod is done and just got to get the oled screen and rotary encoder sorted for the gotek.
More photos later on.
Thanks @PhilC @rubber_jonnie I'll have a trawl through thingverse later to see what is available.
gebes
I received my H5 back from @PhilC and have got it set up :D
Am absolutely stunned and so very impressed with everything Phil has done. Now have ST 536, internal Dreamblaster midi , TOS 2.06, EMU Tos 1.2.1. Internal gotek fed out to an external display,
Playing back a MIDI file , the sound is so very impressive and warm, and adding in the ST 536 everything is so much more responsive. So happy that I'm the proud owner of a souped up H5 :D
So to @PhilC may I take this opportunity to express my thanks for taking this project on for me, patiently answering questions, offering suggestions and the sheer level of pride and care that has been put into this build.
( PS Never any need for apologies for the length of time for the build !! :D )
:bravo: :coolpics: :welcomewave:
@gebes thank you for your kind words. I’m happy to see you’ve got it all up and running.
That Roland sound card is amazing. I’m going to get myself one when I get a mo.
I’ll be starting on our next project very soon (ATX St).
Best wishes
Best wishes
That's excellent work @PhilC ! Just wondering, does the X2 midi automatically get mixed into the audio circuit? I assume so.
@Steve yes it does but needs the audio fixes.
Looks like you're not running maprom and/or running GB6 from altram :)
