Sure :) I'm going to put together 10 kits, Don't think any use in doing more than that..Icky wrote: 16 Aug 2018 22:12 As mentioned I can send you 15x 13pin monitor sockets to add to the kits Chris.
Part kits
Re: Part kits
Axnfell
Re: Part kits
Sounds like a cracking idea, count me in for a few...
James
James
Re: Part kits
Parts below will be in the kit..
The CPU & ROM are £10 each in my store, but will do at half price in this kits.. then helps offset the "double postage cost" for you guys..
Excluding the parts I carry in stock, the "order" to farnell and rapid in total comes to £422 so far, I aiming for 10 kits, so pretty much £42 each for this kits so far.. (plus CPU & ROM +£10 , so £52) this is all "at cost".. and some of the parts I have in stock like resistors I aint even adding those up.. just chucking them in the box..
So I think the final kit cost will be around £55.. I think I just need to add the SIP arrays in it all... I *think* that is basically everything, other than the GLUE, SHIFTER, MMU, DMA etc.
I haven't got the square header pins for the RAM card, or the floppy connector.. I will probably get those from ali, but you guys will have to find those as no use waiting for china to send the bits to me to ship with kits.. could take months else.
Think this could be the floppy one :)
https://www.rapidonline.com/truconnect- ... ch-19-0038
(ORDERED GENERIC)
C1 1UF C-EU025-024X044 C025-024X044 rcl 1
C2 1UF C-EU025-024X044 C025-024X044 rcl 1
C3 1UF C-EU025-024X044 C025-024X044 rcl 1
C4 1UF C-EU025-024X044 C025-024X044 rcl 1
C5 1UF C-EU025-024X044 C025-024X044 rcl 1
C6 1UF C-EU025-024X044 C025-024X044 rcl 1
C7 1UF C-EU025-024X044 C025-024X044 rcl 1
C8 1UF C-EU025-024X044 C025-024X044 rcl 1
C9 1UF C-EU025-024X044 C025-024X044 rcl 1
C11 1UF C-EU025-024X044 C025-024X044 rcl 1
C12 1UF C-EU025-024X044 C025-024X044 rcl 1
C13 1UF C-EU025-024X044 C025-024X044 rcl 1
C14 1UF C-EU025-024X044 C025-024X044 rcl 1
C15 1UF C-EU025-024X044 C025-024X044 rcl 1
C16 1UF C-EU025-024X044 C025-024X044 rcl 1
C17 1UF C-EU025-024X044 C025-024X044 rcl 1
C18 1UF C-EU025-024X044 C025-024X044 rcl 1
C19 1UF C-EU025-024X044 C025-024X044 rcl 1
C20 1UF C-EU025-024X044 C025-024X044 rcl 1
C21 1UF C-EU025-024X044 C025-024X044 rcl 1
C22 1UF C-EU025-024X044 C025-024X044 rcl 1
C23 1UF C-EU025-024X044 C025-024X044 rcl 1
C24 1UF C-EU025-024X044 C025-024X044 rcl 1
C25 1UF C-EU025-024X044 C025-024X044 rcl 1
C26 1UF C-EU025-024X044 C025-024X044 rcl 1
C27 1UF C-EU025-024X044 C025-024X044 rcl 1
C28 1UF C-EU025-024X044 C025-024X044 rcl 1
C29 1UF C-EU025-024X044 C025-024X044 rcl 1
C30 1UF C-EU025-024X044 C025-024X044 rcl 1
C31 1UF C-EU025-024X044 C025-024X044 rcl 1
C32 1UF C-EU025-024X044 C025-024X044 rcl 1
C33 1UF C-EU025-024X044 C025-024X044 rcl 1
C34 1UF C-EU025-024X044 C025-024X044 rcl 1
C35 1UF C-EU025-024X044 C025-024X044 rcl 1
C36 1UF C-EU025-024X044 C025-024X044 rcl 1
C37 1UF C-EU025-024X044 C025-024X044 rcl 1
C940 1UF C-EU025-024X044 C025-024X044 rcl 1
C941 1UF C-EU025-024X044 C025-024X044 rcl 1
C942 1UF C-EU025-024X044 C025-024X044 rcl 1
C943 1UF C-EU025-024X044 C025-024X044 rcl 1
C900 1UF C-EU025-024X044 C025-024X044 rcl 1
(2.5mm x 42)
C10 100NF C-EU025-024X044 C025-024X044 rcl 1
C38 1500uF CP-E-050X100 E-050X100 cap-master 1
C39 1500uF CP-E-050X100 E-050X100 cap-master 1
C40 1500uF CP-E-050X100 E-050X100 cap-master 1
C84 33PF C-EU025-024X044 C025-024X044 rcl 1
C85 33PF C-EU025-024X044 C025-024X044 rcl 1
C901 10UF CPOL-EUE2,5-6E E2,5-6E rcl 1
C902 10NF C-EU025-024X044 C025-024X044 rcl 1
C903 22UF CPOL-EUE2,5-6E E2,5-6E rcl 1
CN1 HDR-1X6-SIP-100 SIP-100-6V con-hdrs40 1
CN2 HDR-1X4-SIP-100 SIP-100-4V con-hdrs40 1
CON1 DB25M/90 D-25M/90 connect 1
CR7 1N4148DO35-7 1N4148DO35-7 DO35-7 diode 1
CR12 1N4148 1N4148DO35-7 DO35-7 diode 1
CR13 1N4148 1N4148DO35-7 DO35-7 diode 1
CR14 1N4148DO35-7 1N4148DO35-7 DO35-7 diode 1
CR15 1N4148 1N4148DO35-7 DO35-7 diode 1
CR16 1N4148 1N4148DO35-7 DO35-7 diode 1
CR17 1N4148 1N4148DO35-7 DO35-7 diode 1
CR18 1N4148 1N4148DO35-7 DO35-7 diode 1
D1 1N4148 1N4148 D-2.5 Atari_MB 1
D2 1N4148 1N4148 D-2.5 Atari_MB 1
D3 1N4148 1N4148 D-2.5 Atari_MB 1
D4 1N4148 1N4148 D-2.5 Atari_MB 1
D5 1N4148 1N4148 D-2.5 Atari_MB 1
D6 1N4148 1N4148 D-2.5 Atari_MB 1
D7 1N4148 1N4148DO35-7 DO35-7 diode 1
(x15)
QG1 XO-8 DIL08S crystal 1
R900 10 R-EU_0204/2V 0204V rcl 1
R901 10 R-EU_0204/2V 0204V rcl 1
R902 10 R-EU_0204/2V 0204V rcl 1
(x3)
R16 100 R-EU_0204/2V 0204V rcl 1
R20 100 R-EU_0204/2V 0204V rcl 1
R27 100 R-EU_0204/2V 0204V rcl 1
R127 100 R-EU_0204/2V 0204V rcl 1
(got)
R5 150 R-EU_0204/2V 0204V rcl 1
R126 150 R-EU_0204/2V 0204V rcl 1
(x2)
R1 220 R-EU_0204/2V 0204V rcl 1
R2 220 R-EU_0204/2V 0204V rcl 1
R3 220 R-EU_0204/2V 0204V rcl 1
R4 220 R-EU_0204/2V 0204V rcl 1
R11 220 R-EU_0204/2V 0204V rcl 1
R26 220 R-EU_0204/2V 0204V rcl 1
(got)
R6 470 R-EU_0204/2V 0204V rcl 1
(x1)
R7 4K7 R-EU_0204/2V 0204V rcl 1
R81 4k7 R-EU_0204/2V 0204V rcl 1
R150 4K7 R-EU_0204/2V 0204V rcl 1
(got)
R28 5.1K R-EU_0204/2V 0204V rcl 1
R17 5.1K R-EU_0204/2V 0204V rcl 1
R21 5.1K R-EU_0204/2V 0204V rcl 1
(x3)
R18 3.6K R-EU_0204/2V 0204V rcl 1
R22 3.6K R-EU_0204/2V 0204V rcl 1
R29 3.6K R-EU_0204/2V 0204V rcl 1
(x3)
R82 3.75k R-EU_0204/2V 0204V rcl 1
R85 3.75k R-EU_0204/2V 0204V rcl 1
R90 3.75k R-EU_0204/2V 0204V rcl 1
(x3 NR)
R83 7.5k R-EU_0204/2V 0204V rcl 1
R86 7.5k R-EU_0204/2V 0204V rcl 1
R89 7.5k R-EU_0204/2V 0204V rcl 1
(x3)
R87 15k R-EU_0204/2V 0204V rcl 1
R88 15K R-EU_0204/2V 0204V rcl 1
R91 15K R-EU_0204/2V 0204V rcl 1
R92 15K R-EU_0204/2V 0204V rcl 1
R93 15K R-EU_0204/2V 0204V rcl 1
R84 15k R-EU_0204/2V 0204V rcl 1
(x6)
R19 33 R-EU_0204/2V 0204V rcl 1
R30 33 R-EU_0204/2V 0204V rcl 1
R10 33 R-EU_0204/7 0204/7 rcl 1
R23 33 R-EU_0204/2V 0204V rcl 1
R24 33 R-EU_0204/7 0204/7 rcl 1
R25 33 R-EU_0204/7 0204/7 rcl 1
R903 33 R-EU_0204/2V 0204V rcl 1
R905 33 R-EU_0204/2V 0204V rcl 1
R906 33 R-EU_0204/7 0204/7 rcl 1
R907 33 R-EU_0204/7 0204/7 rcl 1
R908 33 R-EU_0204/2V 0204V rcl 1
R909 33 R-EU_0204/7 0204/7 rcl 1
R910 33 R-EU_0204/2V 0204V rcl 1
R911 33 R-EU_0204/2V 0204V rcl 1
R912 33 R-EU_0204/2V 0204V rcl 1
R913 33 R-EU_0204/2V 0204V rcl 1
R914 33 R-EU_0204/2V 0204V rcl 1
R915 33 R-EU_0204/2V 0204V rcl 1
R921 33 R-EU_0204/2V 0204V rcl 1
R923 33 R-EU_0204/2V 0204V rcl 1
R59 33 R-EU_0204/7 0204/7 rcl 1
R60 33 R-EU_0204/7 0204/7 rcl 1
R61 33 R-EU_0204/7 0204/7 rcl 1
R62 33 R-EU_0204/7 0204/7 rcl 1
R63 33 R-EU_0204/7 0204/7 rcl 1
R64 33 R-EU_0204/7 0204/7 rcl 1
R65 33 R-EU_0204/7 0204/7 rcl 1
R66 33 R-EU_0204/7 0204/7 rcl 1
R67 33 R-EU_0204/7 0204/7 rcl 1
R68 33 R-EU_0204/7 0204/7 rcl 1
R69 33 R-EU_0204/7 0204/7 rcl 1
R70 33 R-EU_0204/7 0204/7 rcl 1
R71 33 R-EU_0204/7 0204/7 rcl 1
R72 33 R-EU_0204/7 0204/7 rcl 1
R73 33 R-EU_0204/7 0204/7 rcl 1
(x35)
R9 1k R-EU_0204/2V 0204V rcl 1
RP1 1K G08R SIL9 resistor-sil 1
RP7 1K G08R SIL9 resistor-sil 1
R922 1K R-EU_0204/2V 0204V rcl 1
R12 1k R-EU_0204/2V 0204V rcl 1
R13 1k R-EU_0204/2V 0204V rcl 1
R14 1k R-EU_0204/2V 0204V rcl 1
R15 1K R-EU_0204/2V 0204V rcl 1
R58 1K R-EU_0204/2V 0204V rcl 1
R107 1k R-EU_0204/2V 0204V rcl 1
(got)
RP8 2K2 G08R SIL9 resistor-sil 1
RP2 2K2 G08R SIL9 resistor-sil 1
RP3 2K2 G08R SIL9 resistor-sil 1
RP4 2K2 G08R SIL9 resistor-sil 1
RP6 2K2 G08R SIL9 resistor-sil 1
R94 2k2 R-EU_0204/2V 0204V rcl 1
R95 2k2 R-EU_0204/2V 0204V rcl 1
(got)
RP900 10K G08R SIL9 resistor-sil 1
R920 10K R-EU_0204/2V 0204V rcl 1
R8 10K R-EU_0204/2V 0204V rcl 1
R76 10K R-EU_0204/2V 0204V rcl 1
R125 10K R-EU_0204/2V 0204V rcl 1
(got)
R919 12K R-EU_0204/2V 0204V rcl 1
T1 BC337 BC337 TO92 transistor 1
T2 BC337 BC337 TO92 transistor 1
T3 BC337 BC337 TO92 transistor 1
T4 BC337 BC337 TO92 transistor 1
T5 BC337 BC337 TO92 transistor 1
(x5)
U1 74LS05N 74LS05N DIL14 74xx-eu 1
U14 74LS06N 74LS06N DIL14 74xx-eu 1
U32 74LS02N 74LS02N DIL14 74xx-eu 1
U51 74LS04N 74LS04N DIL14 74xx-eu 1
IC900 SN74F04N SN74F04N DIP254P762X508-14 Texas Instruments_By_element14_Batch_1 1
U57 74LS373N 74LS373N DIL20 74xx-eu 1
U58 74LS373N 74LS373N DIL20 74xx-eu 1
U60 74LS244N 74LS244N DIL20 74xx-eu 1
U61 74LS244N 74LS244N DIL20 74xx-eu 1
IC1 MAX238 MAX238 DIL24-3 maxim 1
IC3 74LS11N 74LS11N DIL14 74xx-eu 1
IC4 NE555 NE555 DIL-08 st-microelectronics 1
OK1 CNY17F CNY17F DIL06 optocoupler 1
U64 68000 MC68000FN-SOC PLCC68-S Atari_MB 1
U$5 27C4096 27C4096 PLCC-44 Atari_MB 1
socket plcc 68 x 3
plcc 44 x 1
dip (1772) 28 pin x 1
dip 40way x 3
dip 24 x 2 (ACIA)
dip 14 x4
dip 20 x 4 (373 244)
Re: Part kits
And you said you didn't like soldering any more :D
When you put the list like that, it brings home how much work is involved in planning, let alone building the board.
Well done for putting it all together. Just let me know when and how to pay you.
Re: Part kits
I don't :lol: Would rather someone else build it and try it :P I've gotta catch up on repairs, STE boosters, new PSU's yet :roll:
Indeed.. Its taken a few hours the past couple of days to just look though all the parts to order them...Forgottenmyname wrote: 17 Aug 2018 21:17 When you put the list like that, it brings home how much work is involved in planning, let alone building the board.
:thumbup: They will be in my store at some point.. Farnell stuff is on order now, thats the "special bits" which Rapid don't sell...Forgottenmyname wrote: 17 Aug 2018 21:17 Well done for putting it all together. Just let me know when and how to pay you.
.. but then think how many parts I then have to seperate and re-bag and label after I get all the parts.. that's going to be a all day job in itself! :roll:
Axnfell
Re: Part kits
So as you don’t like soldering, will you be selling the new “red” psu in a kit form?
Just being hopeful....
James
James
Re: Part kits
I'm farming off soldering work to a UK company now.. Increases costs but I don't have time to keep building things up anyway. I wrote a lot about that elsewhere..Axnfell wrote: 18 Aug 2018 11:58 So as you don’t like soldering, will you be selling the new “red” psu in a kit form?
Re: Part kits
Spent most of today putting together these kits , amazing how long stuff like this takes! I've separated stuff into a few bags and labeled up some parts on the bags also.. So you guys will have to refer back to the list as I'm not writing resistor numbers 6 times on each bag, I just wrote "10K" on the bag for example.
I'm missing 20 dip14 sockets and 3.75K resistors.. might have a problem finding them in farnell, but will look again , need to order some ROM's and program them, also test some CPU's out, those will be in the kit for free.
8 kits are listed in my store. I am looking towards the end of the week for shipping.
https://www.exxosforum.co.uk/atari/store2/#0149
Re: Part kits
Good work with the parts kit, will order one in a minute.
Still taking this STFM apart and trying to fix another Mega1.
kodak80
Re: Part kits
Just ordered 2 kits and a couple of WD1772 chips.
Looking forward to putting this together once I have everything.
Users browsing this forum: ClaudeBot and 177 guests
