Re: REV 3 - The beginning
@agranlund The reboot problems seems to be related to Maprom. If I remove maprom from AUTO, I can use keyboard reset and IDE boots every time. If I enable Maprom, IDE boots from power up, but keyboard reset, IDE locks up. Pressing the reset button however works fine, I don't get it ?
agranlund
This is my guess :)exxos wrote: 19 Apr 2022 08:39 @agranlund The reboot problems seems to be related to Maprom. If I remove maprom from AUTO, I can use keyboard reset and IDE boots every time. If I enable Maprom, IDE boots from power up, but keyboard reset, IDE locks up. Pressing the reset button however works fine, I don't get it ?
On first start, TOS206 will be doing its autoboot thing before the MMU has been setup, so you are going to see address $FFFFFA01
Once Maprom is executed it will setup the MMU for TOS206 just how TOS3+4 does it, translating all things FFxxxxxx into 00xxxxxx to prevent pre-32bit software from exploding.
So after the MMU is setup you will see requests for $00FFFA01 instead of $FFFFFA01.
I'm guessing the MMU setup is still active after a TOS206 soft-reset as well.
ahhhh.agranlund wrote: 19 Apr 2022 08:56 This is my guess :)
So basically
localparam PATCH_ADDRESS = 30'hffFFFA01;
localparam PATCH_ADDRESS2 = 30'h00FFFA01;
wire BUSEN_INTREQR = ((A[29:0] != PATCH_ADDRESS) & (A[29:0] != PATCH_ADDRESS2)) | AS30 | ~RW30 | ~IDEINT ;But this is why I went with like
24'hFFFA01-
agranlund
exxos wrote: 19 Apr 2022 09:08But code doesn't fit :(Code: Select all
localparam PATCH_ADDRESS = 30'hffFFFA01; localparam PATCH_ADDRESS2 = 30'h00FFFA01; wire BUSEN_INTREQR = ((A[29:0] != PATCH_ADDRESS) & (A[29:0] != PATCH_ADDRESS2)) | AS30 | ~RW30 | ~IDEINT ;
Yep either something like that, but it becomes cumbersome since you'd want to always be doing two comparisons for other things too (IDE address decoding for example)
I do this in main_top.v
.A({A[31] ? 8'h00 : A[31:24], A[23:0]}),
The correct way would be to check all of the top 8bits though.
The rest of the cpld code then only ever have to consider $00xxxxxx when dealing with hardware registers.
Maybe something similar fits for you? I guess you could check A[29] or A[29:24] ?
Before I made that change, I had something like this in the patch-code to cover both normal and shadow.
(And a similar style check in logic for IDE address decoding)
localparam PATCH_ADDRESS = 24'hfffa01;
wire ACCESS = ((A[31:24] != 8'h00) & (A[31:24] != 8'hFF)) | (A[23:0] != PATCH_ADDRESS) | AS20 | ~RW20 | PATCH;
Just checking the 24bit range seems risky? Wouldn't it potentially react to valid fastram reads when it shouldn't, like a read from $01FFFA01 ?exxos wrote: 19 Apr 2022 09:08 But this is why I went with like 24'hFFFA01 so it would decode 16 & 32bit ranges, but it never worked ?
I don't know how the rest of the 24'hFFFA01 code looked like but I saw this in a previous post, and that one would actually compare 30 bits even though PATCH_ADDRESS only defined 24.
wire BUSEN_INTREQR = (A[29:0] != PATCH_ADDRESS) | AS30 | ~RW30 ;
ahhh yep, I was trying to think how to plug 00 and FF in but beyond my n00b skills.agranlund wrote: 19 Apr 2022 09:26 Before I made that change, I had something like this in the patch-code to cover both normal and shadow.
(And a similar style check in logic for IDE address decoding)Code: Select all
localparam PATCH_ADDRESS = 24'hfffa01; wire ACCESS = ((A[31:24] != 8'h00) & (A[31:24] != 8'hFF)) | (A[23:0] != PATCH_ADDRESS) | AS20 | ~RW20 | PATCH;
Good point , I keep forgetting about alt-ram.agranlund wrote: 19 Apr 2022 09:26 the 24bit range seems risky? Wouldn't it potentially react to valid fastram reads when it shouldn't, like a read from $01FFFA01 ?
I managed to compile using "Exhaustive fit" option ( which I just spotted) .
wire BUSEN_INTREQR = ((A[29:0] != PATCH_ADDRESS) & (A[29:0] != PATCH_ADDRESS2)) | AS30 | ~RW30 | ~IDEINT ;It was indeed the 00 to FF thing.. It does now boot after a keyboard reset! very hard to program stuff when things keep moving about :lol:
Right then.. about this ST-RAM cache thing.. :lol: :pullhair: :stars: :crazy:
@agranlund So trying out MR19 now.
Normal version.
Cache version.
Thing is, there is no ST-RAM cache code in my 536 yet.... :shrug:
Normal version.
Cache version.
With ST-RAM cache enabled in code:
Oddly seems slower. :shrug: I might have screwed the code up :shrug:
Will get FrontBench tested see what happens...
agranlund
Nice!! That's awesome :dualthumbup:exxos wrote: 19 Apr 2022 14:12 It was indeed the 00 to FF thing.. It does now boot after a keyboard reset! very hard to program stuff when things keep moving about :lol:
I don't know how good the fitter is at optimising and if something like this would even take up less space or not?
localparam PATCH_ADDRESS = 24'hFFFA01;
wire BUSEN_INTREQR = ((A[29:24] != 6'b000000) & (A[29:24] != 6'b111111)) | (A[23:0] != PATCH_ADDRESS) | AS30 | ~RW30 | ~IDEINT ;
wire BUSEN_INTREQR = ((A[29:24] != 6'b000000) & (A[29] != 1'b1)) | (A[23:0] != PATCH_ADDRESS) | AS30 | ~RW30 | ~IDEINT ;
That line is better for sure.agranlund wrote: 19 Apr 2022 16:44
I don't know how good the fitter is at optimising and if something like this would even take up less space or not?Code: Select all
localparam PATCH_ADDRESS = 24'hFFFA01; wire BUSEN_INTREQR = ((A[29:24] != 6'b000000) & (A[29:24] != 6'b111111)) | (A[23:0] != PATCH_ADDRESS) | AS30 | ~RW30 | ~IDEINT ;
Struggling with the ST_RAM decode for the cache.. the fitter managed it after like 10mins though!
@agranlund @Badwolf
GB6 seems slower with ST-RAM caches enabled. But FrontBench shows some difference.
FB with MR19_C & ST_RAM decode used - 3145
FB with MR19_C & WITHOUT ST_RAM decode used - 3032
113 frames difference with ST-caches enabled by the looks of it.
I guess having the boost on ST-RAM would be worth the performance hit on GB6 tests (mostly GEM) as its running way faster than stock anyway.
