Basilisk II Atari
General Discussion, STOS.
mikro
Re: Basilisk II Atari
Post by mikro »
I certainly don't mind if you use them. :-) I adapted some existing ones, after all.
agranlund wrote: 17 Apr 2022 00:37 @Badwolf,
If you have the time, would you like to try this test build?
http://www.happydaze.se/wp-content/uplo ... test02.zip
My desk is full of STE at the moment, but will report back ASAP.
agranlund
Post by agranlund »
mikro wrote: 17 Apr 2022 20:09 I certainly don't mind if you use them. :-) I adapted some existing ones, after all.
Cheers! These integrated nicely :)
It feels ok for less intensive stuff, at least in Hatari.
It's never going to be great when running something that modifies a huge part of the screen every frame but for normal stuff it does feel alright-ish.
TT will get a Mac8bit->Atari4bit thingy as well.
It's not going to look super when reducing colors that much, it's mainly to allow 8bit only things to actually run.
I suppose it'll look similar to ScummST, and OpenDune in 4bit mode.
agranlund
Post by agranlund »
agranlund wrote: 18 Apr 2022 16:34 TT will get a Mac8bit->Atari4bit thingy as well.
Or maybe not..
It appears changing the font and icon size makes the desktop just about usable even when scaled from 640x480 -> 320x480 for the TT's 256 color mode :)
Usable enough for locating and launching some game at least.
Hi Anders,
Sorry it's taken a little while. Building & editing has been going on!
Unfortunately I couldn't make it work. I tried a few things, but this is the extent of the issue:
Basically either the screen starts to redraw after initially going to the black/white dither pattern and stops part way (MiNT) or it fills with a solid colour, but then nothing else happens after a fair old while.
I tried with and without overscan (so 768x480/TC and 640x400/TC) with and without MiNT and even with and without DFB1. The latter (stock falcon) didn't even get to filling the screen the first time, I'm afraid.
agranlund
Post by agranlund »
Badwolf wrote: 20 Apr 2022 22:01 Sorry it's taken a little while. Building & editing has been going on!
No worries! I'm just grateful for the help and there's absolutely no rush :)
I started refactoring all that video code after making a big mess of everything adding that emulation feature.
This here is a work in progress that:
Many things changed or moved around so it's hard to guess if those old issues are fixed or not.
It may or may not cause new issues though :)
You can run it in 4bit, 8bit and 16bit modes (I recommend 8bit)
And of course mono which doesn't need emulation.
It's the same thing with ramsize as before.
Use "ramsize" in basilisk.inf to give the Mac at least a couple of megabytes less RAM than what you have free.
(I will make it do the right thing at "ramsize 0" at some point :))
Oh, and this test build should also work on Atari TT.
TT Medium and Low are supported through emulation.
ST/TT mono is native
(68040/060 is not fully supported yet. Video emulation should technically work but it will be horribly slow until I've finished the supporting MMU code for these cpus)
agranlund
Post by agranlund »
This one is almost identical to the one above. Only change is a fix for 4bit mode on Falcon, and palette restoration issues on shutdown.
http://www.happydaze.se/wp-content/uplo ... test03.zip
agranlund
Post by agranlund »
Hmmn.. I may have gotten a bit carried away :lol:
ST-Low resolution emulating 256 color 640x480.
agranlund wrote: 22 Apr 2022 22:39 Hmmn.. I may have gotten a bit carried away :lol:
This is cooler than a polar bear in shades. :bravo:
@agranlund can this take advantage of NOVA graphics?
Return to “SOFTWARE”
Users browsing this forum: Amazon [bot], ClaudeBot and 3 guests
