Hello.
I am experiencing issue with my Atari 520 STF (520 ko). While playing a game the screen suddenly froze. And no way to boot again. In place I have a light blue screen.
I immediately thought of a memory issue. But after checking continuity with great care, i can not find any short. I also change all the ships for new ones but nothing changed. All the ships are powered with 5v.
My Atari does not boot...
The photo below shows the screen I have when starting the machine with the Exxos test cartridge.
Would you have any idea ?
Unless it's a video problem?
Thank you for your help.
520 STF - Blue screen - Ram issue ?
doc
Re: 520 STF - Blue screen - Ram issue ?
The first thing I would try is to reseat the Shifter chip.
kodak80
I fixed a board (STFM 512kb) on the weekend with a similar screen output, blue blocks with a white boarder and it was due to a faulty LS244 chip. I love that my TL866II programmer can test Logic chips. RAM chips turned out to be fine. Once the board booted, I also found a faulty LS373 chip and faulty DMA chip, neither of these last 2 faulty chips stopped the board booting.
I'd clean the MMU and Glue IC pins and sockets as well as the Shifter.
doc
Thank you for theses clues
So I changed the shifter with one functioning on another 520 ST -> Nothing changed
I removed the 2 LS373 without replacing them -> Nothing changed
I changed the 2 LS373 with 2 LS274 (in case I only had that) -> Nothing changed
I piggy plugged a LS244 on one ship -> Nothing changed
I piggy plugged a LS244 on the second chip -> Something changed !!!! Same mess with many colors ;)
Look at the pictures
And after a reset
Any more ideas ? Do you think I should unsolder the suspected LS244 to firmly replace it ?
I own a TL866II PLUS but I cannot find how to test SN74LS chips... How do you proceed ?
And after a reset
DoG
In menu -> [Device] -> [Logic IC test] -> Choose [74244]doc wrote: 14 Apr 2022 17:49 ...I own a TL866II PLUS but I cannot find how to test SN74LS chips... How do you proceed ?...
You should always reseat and clean all removable chips before resorting to soldering or replacing chips. You could cause a problem on top of your original problem.
Have you cleaned and reseated every chip yet?
Users browsing this forum: Amazon [bot], Bing [Bot], ClaudeBot, Qwantbot and 2 guests
