Has anyone tried to setup this combo before? When I try to install all three the Amiga 2000 won't boot. When I run just the TF536 and spitfire, the system boots fine. (I'm trying to build the system around the scsi2sd adapter I have) And I can also boot the system without the spitfire/hard drive and the TF536 and GBAPII++ are listed cards.
Should I just give up on the spitfire and run from a CF? I guess I could just create two different hard drives for this system. (Eventually I plan to change out the TF536, that's why I was trying to get everything to work via SCSI)
TF536 + DKB spitfire + GBAPII++
matt020
Re: TF536 + DKB spitfire + GBAPII++
Give up and use TF536 IDE port.
I have tried two different SCSI cards, A2091 and GVP HC8+, and neither with play the game.
