Also be sure to pay close attention to the pinout. I've highlighted the differences between HM514170AJ and M514265BSL:
Compatible VRAM memory
czietz
Re: Compatible VRAM memory
Hi Christian,czietz wrote: 04 Mar 2022 07:39 Also be sure to pay close attention to the pinout. I've highlighted the differences between HM514170AJ and M514265BSL:
I already linked the CAS lines together as per suggestion elsewhere which hasn't helped, are you saying I should also link the LWE/UWE lines too?
czietz
No. Neither one, nor the other will work. Unfortunately, you need to get RAM chips with the appropriate pinout.Steve wrote: 04 Mar 2022 11:08 I already linked the CAS lines together as per suggestion elsewhere which hasn't helped, are you saying I should also link the LWE/UWE lines too?
mrbombermillzy
@Steve (as usual :lol: ), if you can hang on till next week, I will try to dig out some of this style RAM I pinched from a (IIRC) S3 Virge 2/4Mb PCI card.
May be cheaper than the horrendous Ebay prices if it's a match, but I'm not sure the size or what it is (FP/EDO/?), other than the same package type.
Ah cool thanks man appreciate it.. yeah I was going to have to start looking to buy cards to steal ram from.mrbombermillzy wrote: 04 Mar 2022 19:11 @Steve (as usual :lol: ), if you can hang on till next week, I will try to dig out some of this style RAM I pinched from a (IIRC) S3 Virge 2/4Mb PCI card.
Hi Christian,czietz wrote: 04 Mar 2022 11:35No. Neither one, nor the other will work. Unfortunately, you need to get RAM chips with the appropriate pinout.Steve wrote: 04 Mar 2022 11:08 I already linked the CAS lines together as per suggestion elsewhere which hasn't helped, are you saying I should also link the LWE/UWE lines too?
Sorry to be a pain, I found some originals in Canada for a good price but they want £20 postage :|
You wouldn't happen to be able to help me find a compatible type in Europe by any chance? On ebay.
Thanks
mrbombermillzy
Managed to dig them out as I had a few minutes to myself.
They seem to be 5V 256K×16 CMOS DRAM (EDO) chips according to the datasheet:
https://www.dexsilicium.com/Alliance_AS4C256K16E0.pdf
No good then, as you need fast page. :(
EDIT: Also, if you are looking to buy elsewhere; although my RAM knowledge is a bit rusty, you may want to check that the CAS/RAS timings match with whatever RAM is on there already.
@mrbombermillzy I bought a PCI Ati mach 64 off ebay just now, I can't quite see the ram markings I'm just crossing my fingers that they'll be the right type. If not I'll bite the bullet and buy 2x from the Canadian seller and pay the £20 postage.
mrbombermillzy
I'm guessing it's a bit of a gamble, so I'll keep my fingers crossed for you too. :DSteve wrote: 06 Mar 2022 15:14 @mrbombermillzy I bought a PCI Ati mach 64 off ebay just now, I can't quite see the ram markings I'm just crossing my fingers that they'll be the right type. If not I'll bite the bullet and buy 2x from the Canadian seller and pay the £20 postage.
Next time, maybe ask the seller for closeups? (I did that when browsing through dead STFM boards on Ebay for shifter models).
Most of the time, the seller is happy to oblige.
Darn it... the ram on this board is:
Which I think also will probably not be correct :/
Users browsing this forum: ClaudeBot, gpt [bot] and 3 guests
