You are SO turning into me!!!
:lol:
Hehehestephen_usher wrote: 05 Mar 2022 15:46 Hehe. I'll try not to be totally you, OK. That'd be creepy. :-)
Anyway, just checked the original power supply and that's all fine, except for a horror story inside the mains plug. The neutral was hanging out and the live was about to leave the connector. The screws hadn't been tightened! Goodness knows how it even worked.
Yeah. You can make one up easily. You just need a high current 5.2V, 500mW Zener diode and a 3A quick-blow fuse. DIN socket for input and DIN plug for output. If the voltage goes above 5.2V the Zener turns on and the fuse blows.rubber_jonnie wrote: 05 Mar 2022 15:48Hehehestephen_usher wrote: 05 Mar 2022 15:46 Hehe. I'll try not to be totally you, OK. That'd be creepy. :-)
I believe there is a passthru device for these old PSUs that will stop them killing the C64 if they go bad.
Sounds like you have a plan :)stephen_usher wrote: 05 Mar 2022 15:58Yeah. You can make one up easily. You just need a high current 5.2V, 500mW Zener diode and a 3A quick-blow fuse. DIN socket for input and DIN plug for output. If the voltage goes above 5.2V the Zener turns on and the fuse blows.rubber_jonnie wrote: 05 Mar 2022 15:48
Hehehe
P.S. The alternative is that you ignore the original 5V supply, rectify the 9V AC from the PSU and make your own 5V supply.
:dualthumbup:
The VIC-20 is much the same, really no easy way to do stuff in BASIC, all peek and poke. For the C64, something like the Simons BASIC cart is what's needed. There is another extended BASIC cart that is similar too, both from Commodore.stephen_usher wrote: 05 Mar 2022 18:10 My goodness. Isn't C64 BASIC rudimentary?
No sound commands and no line drawing commands. You have to manually POKE stuff into memory just to do basic stuff. How did they manage to get away with that and selling so many? I guess no-one programmed in BASIC.
Users browsing this forum: ClaudeBot, semrush [bot] and 13 guests
