Uh Oh.Electron inbound
Re: Uh Oh.Electron inbound
stephen_usher wrote: 25 Feb 2022 10:18 Nice case. :-)
Certainly looks like quite a nice match :)
arkadiusz.makarenko
Moderator Team
Moderator Team
Post by arkadiusz.makarenko »
rubber_jonnie wrote: 25 Feb 2022 09:59 Well, got one of these on the way, ElkSD64:
Expands the RAM to 64K and gives SD card storage, looks pretty neat :)
I have been thinking to buy one of those for a while, but I do have Plus1, Pegasus 400 disk drive controller and Mega Games Cartridge. And I mainly use cartridge because it is easiest to use.
~ Stanislaw Lem
arkadiusz.makarenko wrote: 25 Feb 2022 10:47
I know what you mean, I have an 800XL with 2x1050 drives, but almost entirely use my SIDE3 as it is so much more convenient, and I am going the same way for pretty much all my retro machines where possible.
The ELKSD64 arrived yesterday, I have 64KB of RAM and an SD card for disks.
Thought I should check out Elite :)
Have to say the composite output is very sharp.
:dualthumbup:
Looking good!
arkadiusz.makarenko
Moderator Team
Moderator Team
rubber_jonnie wrote: 02 Mar 2022 12:06 The ELKSD64 arrived yesterday, I have 64KB of RAM and an SD card for disks.
Is it monochrome output?
When you do colour mod, then colour bleeding is quite bad. Obviously best it to use RGB
~ Stanislaw Lem
arkadiusz.makarenko wrote: 02 Mar 2022 13:07
Yes, the composite is mono, and though I have modded my BBC Bs for colour composite, I will leave the Electron as is. I have an RGB cable for my BBC B that works just fine with the Electron and through my OSSC. Looks nice and sharp:
Elite appears to run in monochrome regardless.
I wonder if the full BBC version of Elite (rather than Electron specific one) will work on the expanded machine.
stephen_usher wrote: 02 Mar 2022 13:52 I wonder if the full BBC version of Elite (rather than Electron specific one) will work on the expanded machine.
I'll try it later, but I guess if it's a screen mode the Electron can't do, it'd be a no.
Loads and screen corrupts, so no it doesn't work on the Electron it would seem.
Return to “8 BIT CORNER”
Users browsing this forum: ClaudeBot, semrush [bot] and 4 guests
