ALPHA PARTS LIST
ALPHA PARTS LIST
No part numbers yet.. that will take a while to sort through, but mostly generic parts so should be easy to find anyway... but all the parts I think are listed.. needs checking properly yet though..
The 900 range of parts are "new" parts to the design.. thing slike 33R in series with clock lines etc, that kind of thing...
RGB driver transistors & resistors vary in value from the ST as well... BC337 seemed to give better image quality when I tried them last year, though had to tweak the bias voltages a bit... was done in simulation so should match the original, but of course untested...
Partlist
Exported from STFM_E-routed.sch at 03/08/2018 22:11
Assembly variant:
Part     Value          Device          Package           Library                                Sheet
C1       1UF            C-EU025-024X044 C025-024X044      rcl                                    1
C2       1UF            C-EU025-024X044 C025-024X044      rcl                                    1
C3       1UF            C-EU025-024X044 C025-024X044      rcl                                    1
C4       1UF            C-EU025-024X044 C025-024X044      rcl                                    1
C5       1UF            C-EU025-024X044 C025-024X044      rcl                                    1
C6       1UF            C-EU025-024X044 C025-024X044      rcl                                    1
C7       1UF            C-EU025-024X044 C025-024X044      rcl                                    1
C8       1UF            C-EU025-024X044 C025-024X044      rcl                                    1
C9       1UF            C-EU025-024X044 C025-024X044      rcl                                    1
C10      100NF          C-EU025-024X044 C025-024X044      rcl                                    1
C11      1UF            C-EU025-024X044 C025-024X044      rcl                                    1
C12      1UF            C-EU025-024X044 C025-024X044      rcl                                    1
C13      1UF            C-EU025-024X044 C025-024X044      rcl                                    1
C14      1UF            C-EU025-024X044 C025-024X044      rcl                                    1
C15      1UF            C-EU025-024X044 C025-024X044      rcl                                    1
C16      1UF            C-EU025-024X044 C025-024X044      rcl                                    1
C17      1UF            C-EU025-024X044 C025-024X044      rcl                                    1
C18      1UF            C-EU025-024X044 C025-024X044      rcl                                    1
C19      1UF            C-EU025-024X044 C025-024X044      rcl                                    1
C20      1UF            C-EU025-024X044 C025-024X044      rcl                                    1
C21      1UF            C-EU025-024X044 C025-024X044      rcl                                    1
C22      1UF            C-EU025-024X044 C025-024X044      rcl                                    1
C23      1UF            C-EU025-024X044 C025-024X044      rcl                                    1
C24      1UF            C-EU025-024X044 C025-024X044      rcl                                    1
C25      1UF            C-EU025-024X044 C025-024X044      rcl                                    1
C26      1UF            C-EU025-024X044 C025-024X044      rcl                                    1
C27      1UF            C-EU025-024X044 C025-024X044      rcl                                    1
C28      1UF            C-EU025-024X044 C025-024X044      rcl                                    1
C29      1UF            C-EU025-024X044 C025-024X044      rcl                                    1
C30      1UF            C-EU025-024X044 C025-024X044      rcl                                    1
C31      1UF            C-EU025-024X044 C025-024X044      rcl                                    1
C32      1UF            C-EU025-024X044 C025-024X044      rcl                                    1
C33      1UF            C-EU025-024X044 C025-024X044      rcl                                    1
C34      1UF            C-EU025-024X044 C025-024X044      rcl                                    1
C35      1UF            C-EU025-024X044 C025-024X044      rcl                                    1
C36      1UF            C-EU025-024X044 C025-024X044      rcl                                    1
C37      1UF            C-EU025-024X044 C025-024X044      rcl                                    1
C38      1500uF         CP-E-050X100    E-050X100         cap-master                             1
C39      1500uF         CP-E-050X100    E-050X100         cap-master                             1
C40      1500uF         CP-E-050X100    E-050X100         cap-master                             1
C84      33PF           C-EU025-024X044 C025-024X044      rcl                                    1
C85      33PF           C-EU025-024X044 C025-024X044      rcl                                    1
C900     1UF            C-EU025-024X044 C025-024X044      rcl                                    1
C901     10UF           CPOL-EUE2,5-6E  E2,5-6E           rcl                                    1
C902     10NF           C-EU025-024X044 C025-024X044      rcl                                    1
C903     22UF           CPOL-EUE2,5-6E  E2,5-6E           rcl                                    1
C940     1UF            C-EU025-024X044 C025-024X044      rcl                                    1
C941     1UF            C-EU025-024X044 C025-024X044      rcl                                    1
C942     1UF            C-EU025-024X044 C025-024X044      rcl                                    1
C943     1UF            C-EU025-024X044 C025-024X044      rcl                                    1
CN1                     HDR-1X6-SIP-100 SIP-100-6V        con-hdrs40                             1
CN2                     HDR-1X4-SIP-100 SIP-100-4V        con-hdrs40                             1
CON1                    DB25M/90        D-25M/90          connect                                1
CR7      1N4148DO35-7   1N4148DO35-7    DO35-7            diode                                  1
CR12     1N4148         1N4148DO35-7    DO35-7            diode                                  1
CR13     1N4148         1N4148DO35-7    DO35-7            diode                                  1
CR14     1N4148DO35-7   1N4148DO35-7    DO35-7            diode                                  1
CR15     1N4148         1N4148DO35-7    DO35-7            diode                                  1
CR16     1N4148         1N4148DO35-7    DO35-7            diode                                  1
CR17     1N4148         1N4148DO35-7    DO35-7            diode                                  1
CR18     1N4148         1N4148DO35-7    DO35-7            diode                                  1
D1       1N4148         1N4148          D-2.5             Atari_MB                               1
D2       1N4148         1N4148          D-2.5             Atari_MB                               1
D3       1N4148         1N4148          D-2.5             Atari_MB                               1
D4       1N4148         1N4148          D-2.5             Atari_MB                               1
D5       1N4148         1N4148          D-2.5             Atari_MB                               1
D6       1N4148         1N4148          D-2.5             Atari_MB                               1
D7       1N4148         1N4148DO35-7    DO35-7            diode                                  1
IC1      MAX238         MAX238          DIL24-3           maxim                                  1
IC2      68901          MC68901P        DIL48             Atari_MB                               1
IC3      74LS11N        74LS11N         DIL14             74xx-eu                                1
IC4      NE555          NE555           DIL-08            st-microelectronics                    1
IC900    SN74F04N       SN74F04N        DIP254P762X508-14 Texas Instruments_By_element14_Batch_1 1
J3       DIN13          DIN13           13-DIN            Atari_MB                               1
J12                     HDR-1X7-MTA-100 MTA-100-7V        con-hdrs40                             1
JP1                     JP1E            JP1               jumper                                 1
OK1      CNY17F         CNY17F          DIL06             optocoupler                            1
PARALLEL                DB25F/90        D-25F/90          connect                                1
QG1                     XO-8            DIL08S            crystal                                1
R1       220            R-EU_0204/2V    0204V             rcl                                    1
R2       220            R-EU_0204/2V    0204V             rcl                                    1
R3       220            R-EU_0204/2V    0204V             rcl                                    1
R4       220            R-EU_0204/2V    0204V             rcl                                    1
R5       150            R-EU_0204/2V    0204V             rcl                                    1
R6       470            R-EU_0204/2V    0204V             rcl                                    1
R7       4K7            R-EU_0204/2V    0204V             rcl                                    1
R8       10K            R-EU_0204/2V    0204V             rcl                                    1
R9       1k             R-EU_0204/2V    0204V             rcl                                    1
R10      33             R-EU_0204/7     0204/7            rcl                                    1
R11      220            R-EU_0204/2V    0204V             rcl                                    1
R12      1k             R-EU_0204/2V    0204V             rcl                                    1
R13      1k             R-EU_0204/2V    0204V             rcl                                    1
R14      1k             R-EU_0204/2V    0204V             rcl                                    1
R15      1K             R-EU_0204/2V    0204V             rcl                                    1
R16      100            R-EU_0204/2V    0204V             rcl                                    1
R17      5.1K           R-EU_0204/2V    0204V             rcl                                    1
R18      3.6K           R-EU_0204/2V    0204V             rcl                                    1
R19      33             R-EU_0204/2V    0204V             rcl                                    1
R20      100            R-EU_0204/2V    0204V             rcl                                    1
R21      5.1K           R-EU_0204/2V    0204V             rcl                                    1
R22      3.6K           R-EU_0204/2V    0204V             rcl                                    1
R23      33             R-EU_0204/2V    0204V             rcl                                    1
R24      33             R-EU_0204/7     0204/7            rcl                                    1
R25      33             R-EU_0204/7     0204/7            rcl                                    1
R26      220            R-EU_0204/2V    0204V             rcl                                    1
R27      100            R-EU_0204/2V    0204V             rcl                                    1
R28      5.1K           R-EU_0204/2V    0204V             rcl                                    1
R29      3.6K           R-EU_0204/2V    0204V             rcl                                    1
R30      33             R-EU_0204/2V    0204V             rcl                                    1
R58      1K             R-EU_0204/2V    0204V             rcl                                    1
R59      33             R-EU_0204/7     0204/7            rcl                                    1
R60      33             R-EU_0204/7     0204/7            rcl                                    1
R61      33             R-EU_0204/7     0204/7            rcl                                    1
R62      33             R-EU_0204/7     0204/7            rcl                                    1
R63      33             R-EU_0204/7     0204/7            rcl                                    1
R64      33             R-EU_0204/7     0204/7            rcl                                    1
R65      33             R-EU_0204/7     0204/7            rcl                                    1
R66      33             R-EU_0204/7     0204/7            rcl                                    1
R67      33             R-EU_0204/7     0204/7            rcl                                    1
R68      33             R-EU_0204/7     0204/7            rcl                                    1
R69      33             R-EU_0204/7     0204/7            rcl                                    1
R70      33             R-EU_0204/7     0204/7            rcl                                    1
R71      33             R-EU_0204/7     0204/7            rcl                                    1
R72      33             R-EU_0204/7     0204/7            rcl                                    1
R73      33             R-EU_0204/7     0204/7            rcl                                    1
R76      10K            R-EU_0204/2V    0204V             rcl                                    1
R81      4k7            R-EU_0204/2V    0204V             rcl                                    1
R82      3.75k          R-EU_0204/2V    0204V             rcl                                    1
R83      7.5k           R-EU_0204/2V    0204V             rcl                                    1
R84      15k            R-EU_0204/2V    0204V             rcl                                    1
R85      3.75k          R-EU_0204/2V    0204V             rcl                                    1
R86      7.5k           R-EU_0204/2V    0204V             rcl                                    1
R87      15k            R-EU_0204/2V    0204V             rcl                                    1
R88      15K            R-EU_0204/2V    0204V             rcl                                    1
R89      7.5k           R-EU_0204/2V    0204V             rcl                                    1
R90      3.75k          R-EU_0204/2V    0204V             rcl                                    1
R91      15K            R-EU_0204/2V    0204V             rcl                                    1
R92      15K            R-EU_0204/2V    0204V             rcl                                    1
R93      15K            R-EU_0204/2V    0204V             rcl                                    1
R94      2k2            R-EU_0204/2V    0204V             rcl                                    1
R95      2k2            R-EU_0204/2V    0204V             rcl                                    1
R107     1k             R-EU_0204/2V    0204V             rcl                                    1
R125     10K            R-EU_0204/2V    0204V             rcl                                    1
R126     150            R-EU_0204/2V    0204V             rcl                                    1
R127     100            R-EU_0204/2V    0204V             rcl                                    1
R150     4K7            R-EU_0204/2V    0204V             rcl                                    1
R900     10             R-EU_0204/2V    0204V             rcl                                    1
R901     10             R-EU_0204/2V    0204V             rcl                                    1
R902     10             R-EU_0204/2V    0204V             rcl                                    1
R903     33             R-EU_0204/2V    0204V             rcl                                    1
R905     33             R-EU_0204/2V    0204V             rcl                                    1
R906     33             R-EU_0204/7     0204/7            rcl                                    1
R907     33             R-EU_0204/7     0204/7            rcl                                    1
R908     33             R-EU_0204/2V    0204V             rcl                                    1
R909     33             R-EU_0204/7     0204/7            rcl                                    1
R910     33             R-EU_0204/2V    0204V             rcl                                    1
R911     33             R-EU_0204/2V    0204V             rcl                                    1
R912     33             R-EU_0204/2V    0204V             rcl                                    1
R913     33             R-EU_0204/2V    0204V             rcl                                    1
R914     33             R-EU_0204/2V    0204V             rcl                                    1
R915     33             R-EU_0204/2V    0204V             rcl                                    1
R919     12K            R-EU_0204/2V    0204V             rcl                                    1
R920     10K            R-EU_0204/2V    0204V             rcl                                    1
R921     33             R-EU_0204/2V    0204V             rcl                                    1
R922     1K             R-EU_0204/2V    0204V             rcl                                    1
R923     33             R-EU_0204/2V    0204V             rcl                                    1
RP1      1K             G08R            SIL9              resistor-sil                           1
RP2      2K2            G08R            SIL9              resistor-sil                           1
RP3      2K2            G08R            SIL9              resistor-sil                           1
RP4      2K2            G08R            SIL9              resistor-sil                           1
RP6      2K2            G08R            SIL9              resistor-sil                           1
RP7      1K             G08R            SIL9              resistor-sil                           1
RP8      2K2            G08R            SIL9              resistor-sil                           1
RP900    10K            G08R            SIL9              resistor-sil                           1
S1                      255SB           255SB             switch                                 1
SJ1                     SJ              SJ                jumper                                 1
SJ2                     SJ              SJ                jumper                                 1
SJ3                     SJ              SJ                jumper                                 1
SJ4                     SJ              SJ                jumper                                 1
SJ5                     SJ              SJ                jumper                                 1
SV1                     ML34            ML34              Atari_MB                               1
T1       BC337          BC337           TO92              transistor                             1
T2       BC337          BC337           TO92              transistor                             1
T3       BC337          BC337           TO92              transistor                             1
T4       BC337          BC337           TO92              transistor                             1
T5       BC337          BC337           TO92              transistor                             1
U$1      ST_MMU         ST_MMU          PLCC68-S          Atari_MB                               1
U$3      F_RAM          F_RAM           F_RAM             Atari_MB                               1
U$4      SHIFTER        SHIFTER         DIL40             Atari_MB                               1
U$5      27C4096        27C4096         PLCC-44           Atari_MB                               1
U$6      DIN14          DIN14           14-DIN            Atari_MB                               1
U$7      ST_BLITTER-SOC ST_BLITTER-SOC  PLCC68-S          Atari_MB                               1
U$8      CARTRIDGESLOT  CARTRIDGESLOT   CARTRIDGE_MB      Atari_MB                               1
U1       74LS05N        74LS05N         DIL14             74xx-eu                                1
U9       WD1772-00      WD1772-00       DIL28-6           western-digital-devices                1
U14      74LS06N        74LS06N         DIL14             74xx-eu                                1
U16      YM-2149        YM-2149         DIL40             Atari_MB                               1
U31      ST_DMA         ST_DMA          DIL40             Atari_MB                               1
U32      74LS02N        74LS02N         DIL14             74xx-eu                                1
U51      74LS04N        74LS04N         DIL14             74xx-eu                                1
U52_                    6850            DIL24             Atari_MB                               1
U54                     6850            DIL24             Atari_MB                               1
U57      74LS373N       74LS373N        DIL20             74xx-eu                                1
U58      74LS373N       74LS373N        DIL20             74xx-eu                                1
U60      74LS244N       74LS244N        DIL20             74xx-eu                                1
U61      74LS244N       74LS244N        DIL20             74xx-eu                                1
U64      68000          MC68000FN-SOC   PLCC68-S          Atari_MB                               1
U65      ST_GLUE        ST_GLUE         PLCC68-S          Atari_MB                               1
X1       MAB5SH         MAB5SH          MAB5SH            con-hirschmann                         1
X2       MAB5SH         MAB5SH          MAB5SH            con-hirschmann                         1
X3                      DB19            DB19F             Atari_MB                               1
Y1       2.4576         XTAL/S          QS                special                                1
Re: ALPHA PARTS LIST
High res image of the silk screen layer...
It will be useful if someone could find all these parts in Mouser and list the part numbers and quantities required for each part...
Small change, the 2.2K resistors packs will be 4.7K.
There is a 20uF cap in the reset circuit, but will supply a 10uF one (makes no odds to anything).
Any chance of sending a large table to lay it all out on too? :D #noroomtoswingacat
Forgottenmyname wrote: 17 Aug 2018 21:19 Any chance of sending a large table to lay it all out on too? :D #noroomtoswingacat
Do it on the floor like the rest of us! :lol:
kodak80
Post by kodak80 »
Hi Exxos
Just wondering what the voltage rating is for things like capacitors on the new board? 25v?
kodak80 wrote: 18 Aug 2018 13:02
Think there is only 3 caps which are electrolytic and 16v... Most caps are all ceramic now and normally 50+ volts. I've not looked into it.. No need.
Realloy
Post by Realloy »
exxos wrote: 17 Aug 2018 17:06 Small change, the 2.2K resistors packs will be 4.7K.
The Resistor SILs are they Isolated Resistors or Bussed Resistors or even Dual Terminator Packs
/Johan Hansson
Realloy wrote: 02 Sep 2018 16:01 The Resistor SILs are they Isolated Resistors or Bussed Resistors or even Dual Terminator Packs
9 pin common/bused.
