TF536 and H4 Benchmark
Benchmark screenshots for various boosters & machines.
This is a quick benchmark taken with the TF536, with the rom running from fast ram using @agranlund Maprom program.
Not bad for a first attempt but this card will fly once its had all the usual software tweaks applied.
(Btw, ran using EmuTOS)
Re: TF536 and H4 Benchmark
If you run GB6 from fast-ram then it should greatly increase speeds as well.
exxos wrote: Thu Jun 25, 2020 6:01 pm If you run GB6 from fast-ram then it should greatly increase speeds as well.
I'll try that once I find out how. Something to do with setting app flags?
PhilC wrote: Thu Jun 25, 2020 6:10 pm I'll try that once I find out how. Something to do with setting app flags?
Yep, use PRGFLAGS, tick all the boxes for GB6 in the list..
You're not wrong @exxos heres the benchmark with GB6 running and using TT ram.
PhilC wrote: Thu Jun 25, 2020 6:27 pm You're not wrong @exxos heres the benchmark with GB6 running and using TT ram.
Matches SysInfo numbers.. 17 times faster.
@PhilC when you get a moment can you repeat the 2 tests but with the caches turned off ?
exxos wrote: Sun Jan 16, 2022 2:52 pm @PhilC when you get a moment can you repeat the 2 tests but with the caches turned off ?
Probably be a few days before I get time again.
PhilC wrote: Sun Jan 16, 2022 6:22 pm
:poke:
TF536 ST edition - MAPROM1.8E - EMUTOS
D & I cache ON
D & I cache OFF
D ON, I OFF
D OFF , I ON
Return to “BENCHMARKS”
