Falcon 030 vs STE
Benchmark screenshots for various boosters & machines.
Falcon 030 vs STE
16MHZ Data cache ON, Instruction cache ON.
16MHZ Data cache OFF, Instruction cache ON.
16MHZ Data cache ON, Instruction cache OFF.
16MHZ Data cache OFF, Instruction cache OFF.
8MHZ Data cache ON, Instruction cache ON.
8MHZ Data cache OFF, Instruction cache ON.
8MHZ Data cache ON, Instruction cache OFF.
8MHZ Data cache OFF, Instruction cache OFF.
So the 030 running at 8MHz does a pretty poor job and easily gets beaten be a stock STE.
At 16MHz with caches off, it basically isn't much different than a 16MHz STE.. but of course the 030 has more efficient core, so int-div is much faster than a stock STE by far, but other results are not much different.
Cyprian
Re: Falcon 030 vs STE
Post by Cyprian »
which monitor -VGA or RGB?
http://260ste.atari.org
Cyprian wrote: Thu Aug 02, 2018 10:37 pm which monitor -VGA or RGB?
I use RGB to scart.
KyleB
Post by KyleB »
I always imagined the falcon was a mess, but here we are...
Cyprian
Post by Cyprian »
KyleB wrote: Fri Aug 03, 2018 1:09 am I always imagined the falcon was a mess, but here we are...
yep, figures are not so impressive, but when we compare Falcon with similar solutions from the same era, it doesn't look so bad:
                                        Read LW (MB/s)   Write LW (MB/s)
Amiga 1200, 020/14, Chipram                      4.500             6.900
Falcon 030/16, ST-ram                            5.345             6.488
TT 030 32MHz, ST-ram                             7.867             7.867
TT 030 32MHz, Fastram                           12.615            15.772
Here we can see that Falcon with it's 16 bit bus has better memory (read) performance faster than Amiga 1200 with full 32bit bus.
You can't turn the blitter off in the falcon :(
Cyprian
Post by Cyprian »
exxos wrote: Fri Aug 03, 2018 10:09 am You can't turn the blitter off in the falcon :(
NVDI turns the BLiTTER off.
can pls you compare STE with NVDI vs Falcon with NVDI?
Cyprian wrote: Fri Aug 03, 2018 10:22 am NVDI turns the BLiTTER off.
Wonder how it does it ?
Cyprian wrote: Fri Aug 03, 2018 10:22 am can pls you compare STE with NVDI vs Falcon with NVDI?
I only have floppy on my falcon at the moment, so not a simple task to setup :(
KyleB
Post by KyleB »
Cyprian wrote: Fri Aug 03, 2018 9:41 am yep, figures are not so impressive, but when we compare Falcon with similar solutions from the same era, it doesn't look so bad:
The A1200 is about 88% underclocked compared to falc, that read result likewise 84%. So it's understandable. Not to resurrect decades old feud but 4MB Falcon vs 4MB 1200 is surely going to look very different?
Cyprian
Post by Cyprian »
Atually would be understandable if both had the same, 32bit data bus. But A1200 had twice wider data bus than Falcon.
Lets say that "falcon was a mess", then what we could say about slower A1200?
I would not go in that direction. Both machines could be faster but IMO they were great anyway.
Return to “BENCHMARKS”
