exxos blog - random goings on
Been busy printing squares again with the black PLA. It seems printing at a lower temperature of 180c seems to improve things a lot. There is definitely something wrong with this filament though. It looks almost identical to the previous grey square anyway.
I'm currently trying to work out why the dimensional accuracy is always out. I have calibrated the XYZ axis numbers times and it is definitely accurate. However the X axis is always 0.20mm to large (25.2mm instead of 25mm) The Y axis is always short ( 24.83mm instead of 25mm).
So I thought sod it, and recalibrated based on those figures to see what happens...
Now it's spot on.. So printing a 50mm to see what happens...
This was working two days ago :roll: Another day another screwy printer problem :pullhair:
exxos wrote: 27 Jan 2022 15:45 This was working two days ago :roll: Another day another screwy printer problem :pullhair:
I thought buying one was meant to avoid this kind of stuff!!
(Remembers own 3d printer needs some attention)
rubber_jonnie wrote: 27 Jan 2022 16:09 I thought buying one was meant to avoid this kind of stuff!!
The mind boggles! I have given it a good cloud and it seems to be behaving now. I will have to go back to my flash forge at some point because I pretty much replaced everything on that from the ground up anyway now.
exxos wrote: 27 Jan 2022 16:12
I call it a technical tap :)
rubber_jonnie wrote: 27 Jan 2022 16:22 I call it a technical tap :)
"Hard recalibration" we used to call it.
Percussive maintenance.
I have been trying to figure out what the "bumps" were on the edges for a while. It seems it is the perimeter overlap which is causing it. For some reason I had it on 35%, but when I reduced it to 15% the edges are perfectly flat! at least that is some progress finally!
Post by JezC »
exxos wrote: 27 Jan 2022 17:47 I have been trying to figure out what the "bumps" were on the edges for a while. It seems it is the perimeter overlap which is causing it. For some reason I had it on 35%, but when I reduced it to 15% the edges are perfectly flat! at least that is some progress finally!
You need to try it again in a couple of days just to be sure!
JezC wrote: 27 Jan 2022 21:10 You need to try it again in a couple of days just to be sure!
It will be all out of whack by the morning I can guarantee it!
Had to get creative for a spool holder just! :lol:
Users browsing this forum: apple [bot], ClaudeBot, trendiction [bot] and 11 guests
