Brett's STE - Repair thread
Re: Brett's STE - Repair thread
exxos wrote: 26 Jan 2022 23:23 Nice! Test cartridge run yet ? :hide:
No diag cart yet, but I think it may be close by :)
BrettRogersUK
Post by BrettRogersUK »
rubber_jonnie wrote: 26 Jan 2022 23:21 I'm feeling like a minor celebration. I traced A1 and found that it should be connected to pin 2 of the DMA. Only it wasn't, so I hooked it up and I now get this:
Which I am going to take as progress since it looks like something is getting to video RAM, something I'd not seen before.
Clearly some work left to be done, but the little red led on my diag cart which shows ROM access is now flickering, a good indicator that ROM access is at least being tried. It was completely dead up until now.
Clearly something is going on and it is trying, so more checking to be done, I'll need to look at A2 next.
I also added some test points near the GST combel and I can see that A1 & A2 are connected all the way from there to the Blitter, the CPU and finally the ROM and A1 to the DMA. I am also seeing address line pulses all the way through now too.
More to do though, @exxos another one for your crash screen archive :)
I'd call that a minor victory. Well done matey, I salute you! There's life in the old girl yet.
Yippee!!!
Regards,
Brett
derkom
Post by derkom »
Would be interesting (and possibly educational) to know where exactly the track broke. Have you narrowed that down yet?
derkom wrote: 27 Jan 2022 05:57
Not sure yet tbh, this was a late last night thing so all I did was compare with my working machine and wire it up to see what happened.
Will see if I can figure it out a bit later.
BrettRogersUK wrote: 27 Jan 2022 00:40
Yippee!!!
Regards,
Brett
Still a way to go I suspect, but I'm definitely more hopeful now.
Good progress @rubber_jonnie, also a good read of the diagnosis and fixes under the capable hands of Dr RJ :)
Post by JezC »
rubber_jonnie wrote: 26 Jan 2022 23:13
JezC wrote: 26 Jan 2022 17:56 @rubber_jonnie Go on - you know you want to!
:poke: :hide: :fire: :fire: :fire:
Not you too!!
Just thinking it's another skill to add to your existing set!
Also, can be very useful to help work around faults or shortages. ;)
Icky wrote: 27 Jan 2022 08:29 Good progress @rubber_jonnie, also a good read of the diagnosis and fixes under the capable hands of Dr RJ :)
Thank you :)
JezC wrote: 27 Jan 2022 08:55
Not you too!!
Very true :)
An interesting thing happened just now, I powered the STE on and got a normal black border top and bottom, no stripes.
Unfortunately I didn't get a screenshot of it, and when I turned it back on it was back to the stripey screen.
I was hoping the pixies had been in overnight to fix it, but was sadly disappointed, though it did give me a little more hope :)
Users browsing this forum: ClaudeBot, trendiction [bot] and 16 guests
