CDTV Relocator for the TF536
68030 + SDRAM + IDE
Geordi
Re: CDTV Relocator for the TF536
Post by Geordi »
@go0se ,
Does the issue with the TL866 programmer also apply to the TL866II Plus? This text claims it supports M27C1000: http://www.autoelectric.cn/MiniPro/TL866II_List.txt
I have a handful of "27C100-150 1 meg (128K X 8) UV eraseable EPROM. 32 pin ceramic DIP package" (that's all the info I have on them). Will they maybe work for use with CDTV extended roms?
Thanks
supaduper
Post by supaduper »
Geordi wrote: 22 Dec 2021 02:41 @go0se ,
Thanks
The 27C100 will work but you will need Goose's adapter that swaps the pin config so they can be programmed
Geordi
Post by Geordi »
go0se wrote: 16 Aug 2020 23:07 Also, I have ordered 10 of these PCBs and only require 2 or possibly 3, so, should they work, anyone who wants one can have it for the price of postage to wherever you are -
Provided you can supply your own 2 X 16 X 2.54mm headers and 32 position ZIF socket.
Some cheap fake 3M ZIFs that should do the job can be found here :
https://www.aliexpress.com/item/32980585094.html
Do you still have one of these to spare? Postage is to USA 74011. Thank you!
go0se
Post by go0se »
Hi Geordi,
It would probably be faster and cheaper to get the PCBs, ZIF sockets and 2.54mm pitch header pins from China than the postage for a single built adapter.
The Gerbers for the adapter are here:
MC27C1000_Converter_V2.zip
The Zif sockets are here :
https://www.aliexpress.com/item/32985707354.html
You need to order the "32 pin wide" option.
Any 2.54mm pitch round or square header pins will fit depending on your preference. e.g. :
https://www.aliexpress.com/item/32970438934.html
From the same store as the ZIF sockets.
You can give all the extras to your CDTV owning friends as belated Christmas presents ;)
Cheers.
Geordi
Post by Geordi »
go0se wrote: 22 Dec 2021 19:42 It would probably be faster and cheaper to get the PCBs, ZIF sockets and 2.54mm pitch header pins from China than the postage for a single built adapter.
I can populate a simple board (and I already have the header pins), but I've never ordered PCB before. I've seen jlcpcb.com mentioned a few times. Where would you recommend ordering the PCB?
My first priority is upgrading the CDTV OS roms, but I'm looking to get a TF536 for my CDTV. Captain Future told me to make sure I "get one with a low profile adapter so that it fits in the CDTV player with the lid back on".
I can solder, but a 68030 socket and surface mount ICs might be outside my skill and tool sets. Is there anyone assembling low-profile 536s for sell?
go0se
Post by go0se »
If you are ordering the adapter PCBs from JLCPCB then upload the Gerber zip archive attached above to their quote page and select the following settings:
dalek
Post by dalek »
I actually have a relocater designed and tested that takes a single 27C400 instead of the 2x 27C1000 eproms. I'll try and post it up in the next few days.
utri007
Post by utri007 »
go0se wrote: 22 Dec 2021 19:42 Hi Geordi,
I just ordered that set. PCP, socket and headers.
I think this is little confusing. TL866 doesn't say these chips can't programmed. Programming just fails.
8 Bit Dreams
Moderator Team
Moderator Team
Post by 8 Bit Dreams »
That's correct, because MX27C1000 chips has same pinout as MBM27C1001, check Datasheet!
So You still need that Adapter to be able to burn them...
utri007
Post by utri007 »
Here is my attempt to build eprom adapter. Could somebody confirm that components are right side of pcb?
Return to “TF536”
Users browsing this forum: ClaudeBot and 18 guests
