With ehide disabled 3.1 will not boot with 1200 and TF IDE hooked up...same black screen
Diagrom does boot with both hooked up but reports 256Mb ram
TF1230 Eprom issue
- Admin sponsor
Re: TF1230 Eprom issue
Diagrom should report 256Mb of ram. Thats correct behaviour for current diagrom.sparx wrote: 05 Jan 2022 11:00 With ehide disabled 3.1 will not boot with 1200 and TF IDE hooked up...same black screen
- Admin sponsor
runterriblefire wrote: 05 Jan 2022 11:01Diagrom should report 256Mb of ram. Thats correct behaviour for current diagrom.sparx wrote: 05 Jan 2022 11:00 With ehide disabled 3.1 will not boot with 1200 and TF IDE hooked up...same black screen
VERSION FULL DEVS:ehide.device
(or wherever you have the ehide.device installed).
sparx
ehide.device 1.1 (24/07/57)terriblefire wrote: 05 Jan 2022 11:08runterriblefire wrote: 05 Jan 2022 11:01
Built on 18th June 2021 / 15:59:03 (d2874a8)
- Admin sponsor
Ok it probably wont fix the issue but try this fwsparx wrote: 05 Jan 2022 11:16ehide.device 1.1 (24/07/57)terriblefire wrote: 05 Jan 2022 11:08
run
https://www.exxosforum.co.uk/forum/viewt ... =10#p73251
sparx
Thank you...I have already, but will give it another go :)terriblefire wrote: 05 Jan 2022 11:25Ok it probably wont fix the issue but try this fwsparx wrote: 05 Jan 2022 11:16
- Admin sponsor
Do you have some daft sector size on your disks? This can cause issues with ehide as discussed elsewhere. The only thing i can suggest is a test firmware that makes the TF ide become the default to rule out the driver.sparx wrote: 05 Jan 2022 11:27Thank you...I have already, but will give it another go :)terriblefire wrote: 05 Jan 2022 11:25
sparx
I 'seem' to be making progress...terriblefire wrote: 05 Jan 2022 11:32Do you have some daft sector size on your disks? This can cause issues with ehide as discussed elsewhere. The only thing i can suggest is a test firmware that makes the TF ide become the default to rule out the driver.
The original card that I upgraded to 128Mb suddenly decided it would boot from 3.0 rom with both IDE hooked up and addmem enabled...I could see both drives and had full 128Mb.
The only thing I did was disable and re-enable ehide in startup-sequence, using same cf/sd cards and adptors etc :o
The problematic TF board also decided to boot once I'd shortened the IDE ribbon on the TF IDE to 3cm! (It was only 10cm before trimming and worked on the other board)Totally impractical, but major progress...I also flashed that board with the alpha firmware you linked, it boots, both drives there and reports full 128Mb!
Just about to try both boards on 3.1 roms...
EDIT: Problematic board now booted on 3.1!! Just need to work out max length of IDE ribbon
@terriblefire Thank you so much for the time and patience!
I have no clue what made one board spring back to life (apart from the ehide thing) but the other was a combo of fw/cable length
- Admin sponsor
If your IDE cables are longer than a couple of inches forget it. It wont work. You need a buffer. Go0se designed one based on the TF536.
sparx
I never thought to check cable length, I knew it could be an issue but as my 2x 1260 and my other 1230 was ok with 10 to 15cm I never even thought to look in to it!terriblefire wrote: 05 Jan 2022 12:26 If your IDE cables are longer than a couple of inches forget it. It wont work. You need a buffer. Go0se designed one based on the TF536.
But, still very weird how the other one just sprang back to life by simply disabling/reenabling ehide
Ehide worked just fine when that card had 64Mb and it still has a 15cm ribbon
Users browsing this forum: Baidu [Spider], ClaudeBot and 1 guest
