If you are using anything except RC1 you're wasting my time. There are many many issues in previous firmwares. Use that one as I will not discuss any other firmware.sparx wrote: 04 Jan 2022 19:41 TBH, I've lost track...but I have definitely tried RC1 in last few hours, I've tried numerous firmwares from August onwards
After supper I'll jump back on RC1 just to reconfirm - thanks for the time and help!
TF1230 Eprom issue
- Admin sponsor
Re: TF1230 Eprom issue
sparx
No, not time wasting! As soon as you mentioned firmware earlier I tried all firmwares from early August onwards including RC1. The only success (slight) I had was with one I have labelled as BETA2, All others resulted in black screen bootloops or yellow flashing screen.terriblefire wrote: 04 Jan 2022 19:43If you are using anything except RC1 you're wasting my time. There are many many issues in previous firmwares. Use that one as I will not discuss any other firmware.sparx wrote: 04 Jan 2022 19:41 TBH, I've lost track...but I have definitely tried RC1 in last few hours, I've tried numerous firmwares from August onwards
It was then i discovered the ram thing and checked my other card...I will go back to RC1 and post the exact results
- Admin sponsor
There are well known issues pre RC1. Its not worth even looking at them.sparx wrote: 04 Jan 2022 19:56No, not time wasting! As soon as you mentioned firmware earlier I tried all firmwares from early August onwards including RC1. The only success (slight) I had was with one I have labelled as BETA2, All others resulted in black screen bootloops or yellow flashing screen.terriblefire wrote: 04 Jan 2022 19:43
sparx
Back on RC1...with just IDE hooked to 1200 mobo it boots and sysinfo reports 128Mb ramterriblefire wrote: 04 Jan 2022 20:13There are well known issues pre RC1. Its not worth even looking at them.sparx wrote: 04 Jan 2022 19:56
With IDE hooked up to TF card it bootloops on black screen
With IDE hooked up to TF card but no CF card inserted it flashes between yellow and black
I've been thinking this through and now convinced this is not an eprom issue but ram related
The insertion of stock 3.0 roms will let my machine boot as my WorkBench is not set up for addmem so cannot see the TF 128Mb but does see the 2 IDE...
I still need to test this theory by digging out my other 1200 that has a keyboard and will allow me to adjust startup-sequence etc
This is the ram I'm using, I've used it successfully on the TF1260 but I spose that really doesn't mean much...
https://www.mouser.co.uk/ProductDetail/ ... M16SB-7TCN
sparx
With 3.0 setup with addmem it will boot and see 128Mb ram provided I do not hook up the TF IDE - as soon as I do this it will no longer boot, just hangs on a black screen.
Without addmem enabled 3.0 will no longer boot with 1200 and TF IDE hooked up - this is a change n behaviour, possibly related to being on RC1.
Either way, I still believe this to be a ram issue, not sure if a fix in firmware is possible, but happy to just order replacements if anyone has a recommendation please...
- Admin sponsor
Sounds like its a CF card issue. Its been seen before. Not all CF cards will work.. Try a different brand.
Just jumping in here after not reading the whole topic but some CF cards and IDE adaptors will not work on the TF cards that I have, causing a black screen on Amiga or no boot on an ST. Do you have any other IDE devices to try?sparx wrote: 05 Jan 2022 09:32 With 3.0 setup with addmem it will boot and see 128Mb ram provided I do not hook up the TF IDE - as soon as I do this it will no longer boot, just hangs on a black screen.
sparx
I have different adaptors, cables, cf and sd cards....tried all combos, can only get booted if i only use the 1200's IDE (It did begrudgingly boot with both IDE hooked up when on beta2 fw, but only showed 64Mb ram and guru'd before booting)PhilC wrote: 05 Jan 2022 09:38Just jumping in here after not reading the whole topic but some CF cards and IDE adaptors will not work on the TF cards that I have, causing a black screen on Amiga or no boot on an ST. Do you have any other IDE devices to try?sparx wrote: 05 Jan 2022 09:32 With 3.0 setup with addmem it will boot and see 128Mb ram provided I do not hook up the TF IDE - as soon as I do this it will no longer boot, just hangs on a black screen.
Now that both of my 1230's have 128Mb they both now have the same issue - the working card that only had 64Mb was fine until I changed the ram
- Admin sponsor
Well since the IDE interface is not electrically connected in any way to the RAM i dont think there is any correlation.
1. Do you have ehide in rom?
2. If not do you load the ehide during boot?
3. Does the system boot with the cf card in if you dont load ehide in any way.
4. If no to 3 does DiagROM boot.
If DiagROM does not boot with the CF card installed its your CF card. Even if you have 20 of them its the CF card.
EDIT: Infact i'll tell you why it happens. The CF card holds the reset line low. You can even measure it with a multimeter.
sparx
I have ehide in devs and modified startup-sequence, I will disable it and try booting...will also see what happens with Diagromterriblefire wrote: 05 Jan 2022 10:44 Well since the IDE interface is not electrically connected in any way to the RAM i dont think there is any correlation.
Thank you!
