Mega ST project
frank.lukas
Re: Mega ST project
Post by frank.lukas »
Bei der alten Platinenversion (PAK/3-030) müssen noch einige Leitungen gefädelt werden, da das Layout nur die Versorgung des GALs mit Vcc und GND vorsieht. Die neue Platinenversion (PAK/3-030A) enthält alle nötigen Verbindungen, aber mit einem anderen Pinout!
It say the old pcb has only VCC and GND connected to the GAL U3. You must see the schematics from the PAK ...
frank.lukas
PAK68/3-020 40Mhz
PAK.pdf
U3 = puk.jed and not puk_a.jed !
Darklord
Re: Mega ST project
Post by Darklord »
If it helps, here is the English version of the Pak PDF:
PAK_en.pdf
Re: Mega ST project
Post by HigashiJun »
@frank.lukas @Darklord
Thank you both for your feedback.
I have the English version of the manual, so no worries.
The GAL is the "P3-PUK", so no problem here too.
I thought I had the patch Frank is talking about done on my PAK68, but I have realized the bodge wires are just another patch (see the picture below):
So I will have to add my thin gauge wire to make the 68000 work.
Hope to have some free time this week-end...
Darklord
Re: Mega ST project
Post by Darklord »
All of this makes me glad that I wound up with the later version of the Pak board.
It's very interesting to watch you work through these problems. I'm sure they will
submit to your and Franks' technological prowess, in the end! :)
Wolfgang
Re: Mega ST project
Post by Wolfgang »
frank.lukas wrote: 15 Dec 2021 11:40 I ask Idek for a 030 STGA T8 nova driver ...
And here they are. Totally untested since I don't have this setup. But I doubt that it is driver related anyway. The 68000 drivers should also work.
Re: Mega ST project
Thank you !
I will give them a try anyway.
Re: Mega ST project
Ok, one issue is solved. :D
The PAK68 now works with a CPU on top of it, so the fallback mode is operational.
As Frank Lukas wrote, the wire patch at the bottom of the board was missing.
Now, it is applied:
Remains the FDD issue...
Re: Mega ST project
Some more feedback after some quick tests:
- When the PAK is fitted on the CPU relocator, I get RAM errors on the Atari boot screen.
- Fitted directly on the motherboard, no more RAM errors occur.
- The fallback mode does not work with the MC68HC000 CPU and the PAK simply does not boot with this CPU, even in PAK mode.
- Works great with a MC68000 CPU (fallback mode and PAK mode).
- The FDD works in fallback mode (8 Mhz).
- I have no more error message while accessing the FDD in PAK mode, but only a reboot.
That is all for now...
frank.lukas
Re: Mega ST project
pm pakman and ask for tips ...
Users browsing this forum: ClaudeBot and 30 guests
