Willies Falcon service blog (Nov 2021)
Hi guys,
Just working on Willie's Falcon,
We are doing:
  • PSU recap
  • Falcon motherboard re-cap
  • Exxos clock buffer
  • Exxos NVRAM
  • Exxos RAM board
  • Floppy drive clean
  • CF card reader to replace HDD
  • Install FPU
  • Install Fast TOS 4.04
  • Disable wait states
Link to motherboard high res photos
Just checking to make sure it's working as expected to begin with
There are two types of NVRAM on Falcon boards, the Motorola is the most difficult to remove as its legs aren't visible on the top side, so all the work needs to be done from the bottom. The ground plane is very strong so I needed to use my hot air gun while protecting the area with kapton tape
A quick clean up with solder wick
Socket installed
NVRAM installed
Fast TOS 4.04 installed so we can later disable the motherboards wait states
Re: Willies Falcon service blog (Nov 2021)
Clock patch installation
100k resistor added to clock patch on SDMA line
Re-capping the PSU
Steve wrote: 07 Nov 2021 18:52 There are two types of NVRAM on Falcon boards, the Motorola is the most difficult to remove as its legs aren't visible on the top side
I didn't know that. I've still not replaced the NVRAM on my Falcon yet, but it's good to know I've the 'easier' type.
~Willie~
Post by ~Willie~ »
Thanks for posting Steve. Good to see the old bird getting the TLC she deserves.
~Willie~ wrote: 08 Nov 2021 08:16 Thanks for posting Steve. Good to see the old bird getting the TLC she deserves.
No worries man!
Mobo recapped and wait states removed:
~Willie~
Post by ~Willie~ »
Looking good Steve. Looking good....
Just some shots of cleaning the floppy drive, changing the drive motor capacitor, securing the CF card reader with kapton tape and double sided tape.
@~Willie~
~Willie~
Post by ~Willie~ »
Wow Steve, those TOS 4.04 desktop icons are looking pretty cool it must be said. Can't quite get my head around seeing those 1GB partitions. :dualthumbup:
I'm getting excited now ;)
Users browsing this forum: Baidu [Spider], CCBot, Google [Bot], Qwantbot and 28 guests
