DSP-508A in Atari 1040STE
BrettRogersUK
Re: DSP-508A in Atari 1040STE
Post by BrettRogersUK »
exxos wrote: 05 Dec 2021 00:04 I'm not sure about changing value and types without trying them out. I assume the ones you took out are carbon, you may have to chop it up to see. Going from carbon to wirewound , your adding inductance on a wire wound one, without studying the PSU with both types I don't recommend using wire wound, unless you can confirm they are already used.
BTW
If you run a incandescent lamp in series with the mains, say 40 or 60 watt , then it will act as a current limiter. Normally the lamp will light up like 50% if things are going well, if the PSU has failed, the lamp will go full brightness and gives you a few seconds to turn off before the PSU goes boom. I used to that with all the PSUs I serviced in my old job. Evil things they were. I also used to put a heavy catalog on top of it and turn it on across the workshop ! Did I mention those things were evil ? :lol: :roll:
Cricklewood Electronics do 56R Carbon Film resistors in 2W types. I'm just assuming it's a 2W resistor. That's what it lists on the BOM for the PSU schematic that's available. However, the values and where they are placed do not match with what I've got in front of me on the PSU.
The chared resistor I took out does still read at 54R on the multimeter and has also got continuity as well on either end.
Thanks,
Brett
Looks like it's a feedback resistor which turns on a transistor. I doubt a couple ohms higher would really matter that much.
BrettRogersUK
Hi All,
The Saga continues.......
I've replaced the parts (BU508A, 51R resistor and D667 transistor) and I've plugged the power supply in.
The good news is that the power supply didn't go bang or fizzle and the fuse remained intact.
The bad news is that there isn't any voltage on the output pins. I've checked the bridge rectifier. I'm getting 240v on the AC pins and getting 326v on + and - (DC pins).
There is no output on the 5v or 12v lines. Could it be that the bridge rectifier is knackered and that I will need to replace it?
I do honestly think a new power supply will be needed now.
Regards,
Brett
If you have around 350VDC on the capacitor then is generally correct. Careful how you measure that voltage though!!
It sounds like it is not actually switching. I think you are pretty much changed every everything other than the Opto now ? It might be worth a go for a last attempt and then call it a day as it is becomes a point where spending lots of time and money on something just isn't worth it anymore.
Users browsing this forum: Bing [Bot], ClaudeBot, Roberto and 23 guests
