New notification command extension
Latest Atari related news.
Extension description: This extensions add support for mentioning a user by starting to type a @ in the posting field.
Once you select a user from the dropdown, the 'mention' BBCode will be inserted and after submitting the post it will create a notification to that user.
Basically instead of quoting a large chunk of text to get someone's attention to get a reply, you can now just type the member you want to grab attention by by typing the @ and then the member name, you must select the name from the drop down box. Then the "mention" BBcode will automatically be inserted. If you messed it up like @PhilC and @rubber_jonnie did, you will just end up with plain text such as "@philC" which will not work. If you did it right, then the text will be in the mention brackets and be highlighted in red.
For example:
[mention]Icky[/mention]
Feel free to test it out with @Icky as this was his idea :twisted: :twisted:
Re: New notification command extension
So to try it out, do you get one mention per post with an @Icky or is it one notification per @Icky ?
How many notifications do you think @Icky will get from this post exxos? You'll have to let us know how it works @Icky .
I wonder if this is starting to annoy @Icky yet?
:lol: :lol: :lol:
PhilC wrote: 17 Nov 2019 22:47 So to try it out, do you get one mention per post with an @Icky or is it one notification per @Icky ?
I wondered that @PhilC @PhilC @PhilC @PhilC ?
So to confirm @PhilC and @exxos you get one notication from all the mentions in the post you make :)
And no I'm not annoyed I actually like this feature as it saves all the cut and pasting with quotes sometimes just to do a mention.
Icky wrote: 17 Nov 2019 23:05 So to confirm @PhilC and @exxos you get one noticatoin from all the mentions in the post you make :)
@Icky Cool :)
@exxos
@Icky
@PhilC
Well since it seems to have worked on my PC (I get the dropdown now when I type@ and a name) I'm putting it down to trying it on my phone earlier, where it clearly didn't work.
If it didn't work this time, I'm pretty sure you'll all let me know!
rubber_jonnie wrote: 18 Nov 2019 00:01 Well since it seems to have worked on my PC (I get the dropdown now when I type@ and a name) I'm putting it down to trying it on my phone earlier, where it clearly didn't work.
All seems to be OK now :)
I am bumping this topic to remind people of the notification extension @NAME , Basically because I'm seeing people with single line replies, and 10-20 quoted reply lines.
It just makes things a little easier and neater to get peoples attnetion using the @ command rather than quoting 20+ lines which do nothing but causes huge pages of scrolling for people.
BUMP
Have seen a lot of large quotes in posts recently so just reminding users of the mention feature.
Using @NAME will give a drop down to select that user and they will get a notification of the mention. It saves quoting and duplicating large blocks of text.
