CM8833-II Just died
juz400
Re: CM8833-II Just died
Just make sure that the power is off when you short the HT cap to ground, its quite a scary spark if you dont! lol
It could also just be a dry joint around the HT transformer, if it gets bounced in shipping, hairline cracks in the copper tracks around the same area can be an issue.
Tomswork
Is there any high voltage noise from the horizontal output
Tom
Tom
- Admin sponsor
Yeah i already have an arc welder :Djuz400 wrote: 26 Oct 2021 20:33 Just make sure that the power is off when you short the HT cap to ground, its quite a scary spark if you dont! lol
It was working for a while then stopped. I actually collected this one in person so i think it wasnt a transportation issue.juz400 wrote: 26 Oct 2021 20:33 It could also just be a dry joint around the HT transformer, if it gets bounced in shipping, hairline cracks in the copper tracks around the same area can be an issue.
I've not opened it. I am still needing to make or preferably buy a discharge tool.
Danoo
I have had to replace the flybacks on a variety of different monitors. I use a long screw driver with a lead attached to the shaft then insulated with heatshrink and electrical tape near the handle. Other lead end is a low ohm high watt resistor(arc reduction) and a alligator clip.
It is been a while since changing one in a 1084S, but if I remember correctly it is also worthwhile discharging the larger caps on the board with a resistor. I have had my fair share of heart shakers in my early years as a electrical / electronic technician, don't need a top-up. :roll:
As mentioned before, if the flyback is busted then the HOT will probably be near-on dead as well so changing both is good practice. :)
I always found tuning the screen and focus on the new flyback a more scary procedure then discharging the CRT, as the monitor is powered when tuning. :shock:
mikro
Maybe my rejuvenation post can come in handy as an inspiration: https://www.atari-forum.com/viewtopic.php?f=15&t=38417 :)
Danoo
Here is another POV on the dangers of CRT maintenance / repair, a interesting read https://lowendmac.com/2007/the-truth-ab ... ck-danger/
- Admin sponsor
Yeah i've had a few HV shocks over the years and my heart is fine. :)
I'd just like a premade tool rather than relying on my own handywork
- Admin sponsor
I built me a discharge tool and removed the Anode cap without any drama. Just waiting for the replacement to arrive.
I dont have a replacement HOT on order so i guess i'm doing the flyback first.
- Admin sponsor
Dismantled....
- Admin sponsor
Finally got round to finishing this repair..
