Bikerbob's H5 C1 build
Bikerbob
Re: Bikerbob's H5 C1 build
Post by Bikerbob »
OK, so for mine, I did not buy the RTC module because I have a FMCII from B.gossin.
Now.. I know I am forgetting something.. but would not the TOS 2.06 have the Y2k fixed?
Is not MegaSTE etc.. able to set the clock and work right without a Y2k patch?
I know I have US with RTC and thought that this was not an issue anymore, but on the H5 I cannot set the year past 99..
Sorry guys, but where am I looking for this?? I have googled.. but what I am finding is Troed site.. that is still using a fix etc..
Found Aslands RTCX software.. is this better to use? You have to USE SOMETHING though on every TOS except EMUTOS correct?
James
Bikerbob
Post by Bikerbob »
Ok, ran Gembench for 4 hours today. Both floppies working. FMCII working with Dallas1 from Asland.. :)
OK, that said, I would like to put my STorm/Lightning and cloudy in the machine.
SO.. I need to remove the DUAL TOS and the decoder board. I can put the stuff in the 5v slot the decoder was in.
I am not sure how to connect the cloudy to the H5.. anyone done that yet? I assume I am using the same CE pad that the decoder was using.
I will do some examining and see if the group there has any ideas.
Thanks
James
Bikerbob wrote: 14 Oct 2021 19:20 Ok, ran Gembench for 4 hours today. Both floppies working.
So what was the problem then ??
Howwwwwwwww!
Bikerbob
Post by Bikerbob »
exxos wrote: 14 Oct 2021 19:26
What was the problem with the Floppies?? well I think I finally got a bunch of things right.. Got it fitted in the case without the board being flexed.. that plastic "peg" that was not fitting.
I got the jumper combination working for both the 920 and the external floppy - aka the 8/16mhz jumper as well as the forcing not forcing HD jumper.
I took out the YAM the 1772 and the 1.44 gal and reseated them...
Then went about testing.. as I said.. I was not able to get the diag cart floppy speed test to work. but after I fixed the case I noticed the external floppy was working better.. I also got 3-4 floppies that I KNOW worked in both drives.. for testing.. I think the 920 might be running a bit slow.. and I think some floppies were not working with it.. but I cannot be certain.
Bikerbob
Post by Bikerbob »
Steve wrote: 14 Oct 2021 19:45
Howwwwwwwww!
The running of Gembench for 4 hours was just a stress test, wanted to make sure it's running well. I have a blitter in it now. I have everything working... as far as I can tell. SO now I want to move on and get my IDE/ ALT RAM/ USB/ RTC/ DUAL TOS with EMU TOS in there.
James
Bikerbob
Post by Bikerbob »
Ok, so it looks like the Thunder/Storm/Lighting/Cloudy is going to fit into SLOT 2 - cloudy on bottom Thunder/Lighting middle and Storm on top.. That clears the keyboard and the MFP. RP2 pin on Lighting to CE on board.
BUT - I need to get a line from the lighting INT to pin 10 of the DMA port. I have not read it anywhere.. there is no access point to the DMI INT line on the board is there? OR will I have to try and get to the pin at the socket?
James
There are two pads on the C1 which give you access to that pin.
C2 will have the additional pad as illustrated above.
Bikerbob
Post by Bikerbob »
exxos wrote: 14 Oct 2021 21:38 Capture.JPG
ahhh.. well I soldered to the pin since it was easy to access.. all good!
Bikerbob
Post by Bikerbob »
Can anyone confirm for me that the traces that I am trying to use to pick up the 5 volts and ground are indeed what I think they are?
Return to “H5 C1 USER BUILDS”
