STE V1.5 32MHz BOOSTER - STATUS
Help & information about the STE V1 series boosters.
Re: STE V1.5 32MHz BOOSTER - STATUS
So slightly annoyed now.. the dualtos boards are missing the 2 inner layers :evil: So its going to push back this project again as I can't test the new boards now :(
I will try and hard wire the missing layers.. The via's are there.. I used copper fill on top layer connected to 0V so hopefully that will be enough to get a board working.
EDIT2:
Now working!
Made a start on the (hopefully) last revision of the booster...
Looking good to me.
C1 is a little wonky though :P :lol:
Forgottenmyname wrote: 10 Jul 2018 21:24 C1 is a little wonky though :P :lol:
I charge more for unique items like that ;)
40MHz running on this version.. Worked first time.. so wondering what I did wrong :lol:
Forgottenmyname wrote: 10 Jul 2018 21:24 Looking good to me.
About the same as C3 ;)
Am I seeing things, or does the new dual TOS board only use 8 pins of the HI socket now? In other words just the data lines and GND?
rubber_jonnie wrote: 12 Jul 2018 14:51
I think the SMT pads are to big for the parts.. that's what happens when you cut corners as use "built in libs" :roll: :lol:
rubber_jonnie wrote: 12 Jul 2018 14:52 Am I seeing things, or does the new dual TOS board only use 8 pins of the HI socket now? In other words just the data lines and GND?
Not seeing things no.. I've moved the SMT socket there so pins had to go.
:bravo:
PCBs on order, so a waiting game next :) :ball:
I've got 2 more PCBs here, so will order parts next week , see if I can build them up as pre-release boards :)
Return to “STE V1 SERIES 32MHz BOOSTER”
