I had a report about the 1230.. Seems RAM type can make a difference to how things behave. Probably because I have the RAM timings quite tight on the 1230.
I list the models in case you want to add it in the forum so that people know about it.
Insignis "NDS36PT5-20ET" for 64 MB: When a CF is connected the workbench does not show the memory, in case of bridging the RAMOE signal to GND the workbench shows the memory but gives random read errors in WHDLOAD.
Alliance "AS4C32M16SB-7TCN" for 128MB: When a CF is connected the workbench does not show the memory, in case of bridging the RAMOE signal to GND the workbench shows the memory but gives random read errors in WHDLOAD.
Issi "IS42S16320F-7TL" for 128MB: Everything works perfect in all circumstances without errors in WHDLoad.
P.S. Alliance and Insignis are used in the TF330 without any problems.
TF1230 Beta Interest (Open Source)
- Admin sponsor
Re: TF1230 Beta Interest (Open Source)
8 Bit Dreams
- Moderator Team
Such a pity...
Ordered 20x Micron's, was under impression we used them on TF330..
Getting Lockups with them, also
ISSI IS42S16320B-75TLI are not working
Samsung K4S561632-UI75 not working also
Seems I need more RAMs...😅
alenppc
- Moderator Team
The samsungs are working fine for me... you probably have some soldering issues.
go0se
Where did you get IS42S16320B-75TLI ? Are they made up component suffixes from AliExpress?
PaulJ_2.0
64MB IS42S16320B-7TL are working fine here and display 128MB fine.
PaulJ_2.0
They are on the official Datasheet as Industrial Range.go0se wrote: 30 Sep 2021 19:19 Where did you get IS42S16320B-75TLI ? Are they made up component suffixes from AliExpress?
Maybe 133mhz is just a touch too slow?
go0se
They're not on the official data sheet I'm looking at, I see 6TLI, 7TLI, 75ETLI but no 75TLI
Can you send me a link to the sheet you're referencing?
PaulJ_2.0
If you check his picture, you can see his are 75ETLIgo0se wrote: 30 Sep 2021 19:37They're not on the official data sheet I'm looking at, I see 6TLI, 7TLI, 75ETLI but no 75TLIPaulJ_2.0 wrote: 30 Sep 2021 19:22
Sorry, there has been a little confusion here, I thought you were querying the 'I' part. I looked at his chip and the datasheet and confirmed they were there.
8 Bit Dreams
- Moderator Team
Oh, sorry, my bad, I mean IS42S16320B-75ETLIgo0se wrote: 30 Sep 2021 19:19 Where did you get IS42S16320B-75TLI ? Are they made up component suffixes from AliExpress?
Would be nice if they could work, these are very cheap, about 2$ for each, it's a good price for 64Mb ...
nope if I boot ATK from Gotek it shows no errors on RAM, however booting from IDE usually breaks up and activity LED stays on...alenppc wrote: 30 Sep 2021 19:09 The samsungs are working fine for me... you probably have some soldering issues.
alenppc
- Moderator Team
Ok then it's a broken CPLD. I have no issues here whatsoever. I let it play softfloat Quake, frontier or anything else on a loop for days on end, no crashes. Try replacing the CPLD.8 Bit Dreams wrote: 30 Sep 2021 20:41 nope if I boot ATK from Gotek it shows no errors on RAM, however booting from IDE usually breaks up and activity LED stays on...
