Yes, sorry.. I just got that.. I now understand what the * on the motherboard means.. I changed my question Exxos.. sorry.exxos wrote: 22 Sep 2021 20:46It is explained in the jumpers page, it is also explained on the motherboard, and it is even shown in the image I posted above just.Bikerbob wrote: 22 Sep 2021 20:44 OK I read your thread on the 920 mods Exxos, but I only see where you are using your HD mod board. Where do I attached the HD detect wire (white wire in your image) to the H5 c1 board?
1.44mb floppy on H5 C1
Bikerbob
Re: 1.44mb floppy on H5 C1
If you mod the drive as Frank suggests, and not use JP18.. I would assume it would work.. But of course like I said at the start I have never modified or used one of those drives.
Bikerbob
Thanks Frank, I did find a 920 drive.. so I decided to mod that.. that way I can use my 1.44s in the TT and the MegaSTE
SO the 920 has been modded. The first one shows the solder joint to the lower SW3 I think it is marked.
The 2nd shows to pin 2 and then the DSEL to 0
Really sorry all, if I am asking stuff that has been asked. I like not to make mistakes, and most likely ask too much.
James
James
It looks like your red wire is in the wrong place..
The drive select jumpers should not be needed on the H5 anymore. So does not matter if you change them or not.
Bikerbob
So I am going to assume that this works on a hardware level, TOS does not seem to see an HD drive in there. AKA I cannot use FORMAT in 2.06 to format the drive, it sees only SD not HD. IS that correct?
Kobold seems to read the 1.44 np, and shows the correct disk size.. also just selecting the ICON opens the drive np.
James
James
TOS206 is not aware of 1.44 floppies.. I think on the MSTE there was jumpers to enable it on desktop, but that hardware doesn't exist on the ST range.Bikerbob wrote: 22 Sep 2021 22:20 So I am going to assume that this works on a hardware level, TOS does not seem to see an HD drive in there. AKA I cannot use FORMAT in 2.06 to format the drive, it sees only SD not HD. IS that correct?
@Bikerbob you can run a program to set the _FDC cookie that will enable the HD option in format etc.exxos wrote: 22 Sep 2021 23:00TOS206 is not aware of 1.44 floppies.. I think on the MSTE there was jumpers to enable it on desktop, but that hardware doesn't exist on the ST range.Bikerbob wrote: 22 Sep 2021 22:20 So I am going to assume that this works on a hardware level, TOS does not seem to see an HD drive in there. AKA I cannot use FORMAT in 2.06 to format the drive, it sees only SD not HD. IS that correct?
I think there might be a better link but found some links to some PRGs in this thread. https://www.exxosforum.co.uk/forum/viewt ... 418#p31148
@Icky did we look into it , in that if we emulated the MSTE address, it would enable the cookie install ?
Yes. TOS 206 only looks for those jumpers / address if the machine is an STE, ST BOOK or MEGA STE. Thus you would have to patch TOS. So it's easier to use these PRGs instead.exxos wrote: 23 Sep 2021 01:39 @Icky did we look into it , in that if we emulated the MSTE address, it would enable the cookie install ?
