TF1230 Beta Interest (Open Source)
68030 + SDRAM + IDE
supaduper
Re: TF1230 Beta Interest (Open Source)
Post by supaduper »
have not time now but I will put os 3.2 roms in and see if I get the same problem as you
markus0321
Post by markus0321 »
supaduper wrote: 18 Sep 2021 19:26 have not time now but I will put os 3.2 roms in and see if I get the same problem as you
I did the ScsiSpeed tests and it's probably a problem with this PLATINUM card.
On other CF cards it works ok and it's like this:
1.Stec 1GB - 2.5 MB / s
2.WD -SiliconDrive 2GB - 3GB / s
3.Kingston 4GB - 3.2GB / s
4.CompactFlash (with Ali) 16GB - 2.8GB / s
5.SD to IDE adapter with 8GB sandisk ultra card - 3,2MB / s
6. 2.5 "HDD Samsung 80GB - 5.4MB / s
I did tests on kickstart 3.1 and only setpatch, loadwb and mufastrom before ScsiSpeed.
ICRY
Post by ICRY »
Hello
I am not sure if anybody has post about a rev1b yet, if not hope to let you know my findings in a week or two, & any timing fixes if needed..etc
& if people have, then please forgive me well just once
supaduper
Post by supaduper »
markus0321 wrote: 18 Sep 2021 18:58
supaduper wrote: 18 Sep 2021 18:31 Do you get an eror message when it is using LoadModule on bootup, what Amiga OS you using ? what partition size have you got on the CF card on the TF1230 IDE port
Boot without startup-sequence from DF0 drive:
Load module devs: ehide.device => system reboots without messages and reloads from floppy but ehide.device is not loaded in memory and no partitions mounted in system are visible.
I set up the partition with a small 200mb for testing and it will start normally in the controller from the motherboard. I have kickstart 3.1 but I have OS 3.2 installed.
So I just installed 3.2 roms and ehide.device and yes I get the same fault no boot, this is defo software problem, will have a look later
markus0321
supaduper wrote: 19 Sep 2021 15:26
Today everything works fine for me, yesterday the problem was the CF card on which I had the system installed. Other cards I have work properly with ehide.device and rom 3.1 and 3.2. Well, unless it's a coincidence of a card and software problem at one time.
I noticed, however, that ehide.device does not want to cooperate with another CF Stec 2GB card, but not always. in this case, I solved the problem by soldering a small MLC 100uF 16V type capacitor to the power pins on the IDE2CF adapter, after this procedure the driver works every time.
markus0321
markus0321 wrote: 19 Sep 2021 16:44
I did one more test and compiled kickstart 3.2 + ehide.device with Remus. Now it works very well even with the card that previously had problems with ehide and loadmodule!
Danoo
Post by Danoo »
I gave the TF1230 a real work-out over the weekend and IMHO this card hits the economical functional sweet spot with a A1200. I think the word maybe out, as the build components required are disappearing rapidly. :P
Danoo wrote: 20 Sep 2021 04:39 I gave the TF1230 a real work-out over the weekend and IMHO this card hits the economical functional sweet spot with a A1200. I think the word maybe out, as the build components required are disappearing rapidly. :P
Amiga people want cheap. Thats the most important thing for them .
kulamario
Post by kulamario »
I wanted to order soldered bird seeds PCB but I don't know what's going on with these black spots
Would someone be able to explain to me whether this is to be the OK or something is wrong
kulamario wrote: 20 Sep 2021 23:14 I wanted to order soldered bird seeds PCB but I don't know what's going on with these black spots
Would someone be able to explain to me whether this is to be the OK or something is wrong20210920_225727.jpg
If its from JLC ignore this. Their rendering software is wrong. Use the CPL files i posted.
Return to “TF330”
Users browsing this forum: ClaudeBot and 194 guests
